Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Amp Clipping/Only Rear from Soundcard
  1. #11
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Ok thank you..Yeah, I currently have WAV at 75%, KX db around -4 for the front and at -21 to prevent the rear clipping, and the Winamp is 100%. Now, If I were to drop my winamp to 15% I would barely get loud enough.. I'll mess around with now and let ya know.. I also do have the DSP to default.
  2. #12
    Nov 2007
    PA
    SOLVED: Alrighty. Went to disconnect the Rear Speaker wires from the amp and noticed something odd. With only one wire from the right rear speaker connected, there was still sound. I then noticed that the rear speakers sounded "unequal". So it baffled me how with only the Posotive wire attatched to the amp that there was still sound. So, upon opening my rear door panel the speaker moved and the sound became 100% clear. It now became aparent that the bracket on the speaker where the posotive and negative wires attach, had come into contact with the body and had been grounding itself throughout. Once I readjusted the speaker and secured it better, wola...PERFECT, LOUD, Crisp sound...Thank you all.....I feel stupid now.
  3. #13
    Jun 2005
    Atlanta, Georgia
    Good deal, glad you got it working. Was a wiring issue as many suggested, albeit an odd one. =)
  1. [CoupeE46] BMW E46 2001 330ci CarPC ...
    By CoupeE46 in forum Worklogs
    Last Post: 10-02-2008, 07:16 AM
  2. YES!!! Yet Another Amp Problem
    By CaptainTrap in forum Car Audio
    Last Post: 03-24-2007, 09:58 PM
  3. Could my amp be bad or did i miss something?
    By sansoo24 in forum Car Audio
    Last Post: 03-05-2007, 01:45 AM
  4. Amp behavior.
    By enitalp in forum Car Audio
    Last Post: 05-01-2006, 08:06 AM
  5. Sound quality from soundcard to amp?
    By senseless228 in forum Newbie
    Last Post: 04-16-2005, 05:11 AM
