Results 1 to 10 of 14
Thread: Do I Need an Amp?
    Mar 2008
    Do I Need an Amp?
    I have a 1999 Subaru Outback Station Wagon. I am going to order 2 pairs of 300 watt Soundstorm F365 and a Pioneer Premier DEH-P390MP deck. My question is with that much power do i need an amp?
    Cody
    Constant Bitrate the_crooked_toe's Avatar
    Jul 2007
    Louisville, KY
    the deck has pre-amp outputs...you dont "need" an external amplifier...also i've never even heard of this brand of speakers..be weary...
    Mar 2008
    Those speakers are quite cheap. I highly doubt they are 300 watts. I am guessing they are using clever wording in their description. (1 pair of 150 watts = 300 watts). Plus that wattage is probably peak.
    I would assume the rms wattage would be more like 75 watts.
    75 watts for mid range speakers is plenty though.
    Your head unit will output 22 watts to each speaker. You could use a small 4 channel amp.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    never used there speakers but i've owned several soundstorm amps (using one now) and i've never hadda problem with it
    Live mp3Car Facebook Chat
    Mar 2008
    well i am not trying to make the neighbor hood shake i just want something with decent bass that is better than my factory stock stereo
    and also an amp really isn't in my price range i just don't want to blow the deck
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    you won't "blow your deck" as long as your speakers are the correct imedance for the head unit.
    your pioneer head unit is more powerful than most stock radios, so it should be a significant increase in power output. you will also get more control over the EQ. (most stock radios cut the bass out at higher volumes to make up for an underpowered amplifier and to protect the cheap stock speakers). an external amplifier can provide cleaner, more powerful sound than any head unit but if you're only looking to improve your stock sound then the head unit upgrade will probably be fine.
    just because the speakers say '300 watt' doesn't mean you need to feed them anywhere near that much power. that is a peak/max power rating and is probably exaggerated quite a bit as well. I would suggest you get better speakers than those cheesy soundstorms, they probably won't sound much better than your stock speakers.
    Mar 2008
    Well if you are only feeding 22 watts to speakers rated at 75 watts they will not be very loud at all. You would turn it up all the way and they would be around medium volume.
    Plus turning up the volume all the way on your head unit can cause your output signal to clip..making the speakers sound bad.
    A small 4 channel amp is not that expensive.
    Either get an amp, or get some lower wattage speakers.
    Oh, and 22 watts isn't really much more power than most OEM cars now. The standard now is more often around 45 wattage outputs for after market head units now.
    Mar 2008
    well i thought that too, but i looked at their website and they look legit, but that could just be the site. i am ordering them from onlinecarstereo.com and it is only $22 a pair so it isn't that big of a loss
    May 2007
    Boston
    Quote Originally Posted by ArcaneDreams View Post
    you are confusing peak output with RMS/continuous output. no head unit can output 45 watts of continuous power [per channel].
    most modern head units (including the Pioneer head unit referred to in this thread) are rated for ~45 watts peak/max output, ~22 watts RMS output.
    Woodbridge, VA
    Blog Entries
    41
    Quote Originally Posted by FusionFanatic View Post
    most modern head units (including the Pioneer head unit referred to in this thread) are rated for ~45 watts peak output, ~22 watts RMS output.
    correct. There are a few high end alpine units putting out 55 per channel MAX. But nothings putting out anywhere near 55 RMS.
  1. Replies: 38
    Last Post: 11-30-2010, 05:04 AM
  2. Engine Noise due to ground loop or amp?
    By matt11601 in forum Car Audio
    Last Post: 08-26-2009, 08:38 PM
  3. Replies: 6
    Last Post: 03-20-2007, 10:16 PM
  4. Replies: 3
    Last Post: 12-07-2004, 06:34 PM
