Results 1 to 5 of 5
Thread: changing faceplate of tweeter?
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    Hi,
    It's been a long time since I've been here, but now it's time again to slowly gather new components that should be built in the upcoming car.
    I got a small question to our fellow SQ-freaks (Red, scott, durwood,... I'm sure you could give me an answer).
    Does it drasticaly affect the sound and parameters if I change the (plastic) faceplate from the peerless HDS tweeter to cupper or plexi? I want them to match with the theme of the car which is gonna be either a smooth orange or blue glow(that's why plexi is an option, because I would be putting an LED in each tweeter pod, behind the magnet, so it's glowing through the plexi), or cupper trim throughout the vehicle.
    Grtz,
    Xenia
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
    Feb 2008
    Huntington NY
    That depends on what the tweeter faceplate is designed to do. If it's simply protection from fingers, changing it won't be a problem. If the faceplate includes a small disc placed very close to the center of the dome--the disc may have a small hole in the center, then changing it may be a big problem. If it's the little disc, it's designed to reflect some of the sound back to the dome which will boost some frequencies and attenuate others. The frequencies affected depend on the size of the disc and its diameter. If it's one of those, you'd have to replicate it precisely to have the same frequency response.
    Andy Wehmeyer
    Product Marketing Manager
    Harman Consumer Group
    Mobile, Portable and Companion Products Division
    Jun 2006
    Abele, Belgium
    Problem is I don't know. That's why I asked if it would affect that specific tweeter. Tearing it apart to see if it's only there for protection would be risky if it's not.....
    CLARION HX-D2
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    i think there is a bit of a 'wave guide' built into that tweeter faceplate. one thing you can try is to remove it and pull a mold of it. then you can get some clear acrylic resin and cast the new piece. It isn't hard to do at all.
    i've used this with great results for making molds:
    http://www.smoothonsecure.com/store/...594d30127efb10
    and then all you need is the clear acrylic resin and you'll have a clear replica.
    i'm not sure about the clear smooth on resin but last time i checked into it it was very expensive. I used a different product and had great results. you can also buy tint for the clear if you want to go that route.
    this is what i used:
    http://www.pearlpaint.com/shop_detai...sku~967495.htm
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Maximum Bitrate boomintrac's Avatar
    Apr 2005
    2hr west of Chicago
    Bro I would toss an e-mail to peerless just to be on the safe side, I looked at a pic of the Tweet and it doesn't look like it would be very difficult to make an exact replica of the piece in question. The difference in hardness, type, and texture of plastic used may alter the sound but I don't know enough about large format tweeters to say for sure.
    Aron
    Absolutely 100% stock
  1. Remote faceplate! turned out really nice, check it out
    By Sporttracguy in forum Car Audio
    Last Post: 02-23-2007, 02:07 AM
  2. Relocating faceplate on an alpine deck
    By BavarianBuilt in forum General Hardware Discussion
    Last Post: 10-29-2006, 11:48 PM
  3. Alpine remote faceplate install
    By Hark in forum Car Audio
    Last Post: 10-20-2005, 09:23 AM
  4. pioneer headunit faceplate question
    By carabuser in forum Car Audio
    Last Post: 04-06-2005, 06:10 AM
  5. hacking a stereo faceplate? been done?
    By telekineticfool in forum Input Devices
    Last Post: 08-12-2004, 05:16 PM
