Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: wiring???
    Apr 2008
    how would you wire this???
    i have; two 750 rms subs, one 20 farad cap, two dry cell batteries(divided by an isolator), and two htc amps. one amp goes at 600 rms 4 ohms each channel by two channels to my two subs (not bridged at 4 ohms), the other amp is 75 rms 4 ohms by four channels that go to my 100 rms component speakers. what would be the proper way to wire all of this together needing the cap to go to both amps and the batteries to remain isolated?"
    would it go something like this?
    power supply
    using 0 gauge wire; car battery + to isolator, isolator to the second batteries +, ground second batteries - to the car, from second battery to big fuse (with a handle of the load of both amps.) to the cap +, ground the - of the cap to the car, + of the cap to a power distribution block, one 0 gauge down to 2 4 gauge wires, one wire (4 gauge) to a fuse (big enough for the first amp) to the first amp, the other wire to another fuse for and to the second amp. (matching the fuse to the recommended size for the second amp the second amp.), run the remote wire to both amps.
    speakers
    now the first amp, say it powers the subs (750 rms). run the rca cables to it, ground it, run the speaker wires to the subs however you want to. as for the second amp, it powers your components. run the remote, ground it, NO RCAs to this one instead run all speaker outs on the head to it, take all channels from amp out to the cross overs, cross overs to components.
    Apr 2008
    please help
    that was a question. i want to know other opinions about the equipment i have, so please, i need help. would that be a correct way to wire my car audio? i thought this was a high end audio forum not a bunch of numb skulls.
    Low Bitrate sedtc's Avatar
    Jul 2006
    tally-ho, fl
    let me be the first to inform you, this thread is posted in the wrong section. this is a general car audio question and would probably get a better response if posted there. please bare in mind that this forum is about car audio with respect to car computers. you may also want to reconsider insulting the very cabal you are trying to reach. with the level of your questioning, you don't appear to be in any position to suggest that this forum is "a bunch of numb skulls."
    now on to your question: your wiring seems okay for the amps but you should use a fused power distribution block in between your cap and your amps and you should use a distribution block for your amps' grounds as well. i don't suggest wiring the subs "however you want to," you should be considering impedance loads and without knowing more detail about the equipment you are using, you will only get general information in that regard.
    I also have concerns about using the speaker level inputs on your amp instead of RCA interconnects. you will be injecting unneccessary distortion into your system by using the speaker level inputs. a 20 farad capacitor seems a bit exorbitant to me, but (thankfully) it's your car and not mine.
    Apr 2008
    thanks for the information on the distribution blocks.
    i am running two jl w7 subs. they have a rms at 750 and a peak of 1500, both single voice coil, 2ohm competition subs. an audiobahn2300 htc amp with an rms at 2ohm of 600 wats per channel, so a simple wiring will do me fine to match the two pieces together.
    i always thought on a high pass amp you needed to amplify the speakers signal from the deck to your amp then out to all of your car speakers. thats why if you look at one there are 8 speaker wire tabs in and 8 out. i am running an audiobahn 4 channel htc amp, witch pushes 75 wats rms per channel and 4 2 way component jl zr speakers with an rms at 100 wats handling.
    my head unit is a kenwood x991.
    my cap is a kole audio 20 farad. the reason for this is, i can't replace my alternator in my car. they don't make a replacement (yet) for such a new car. i also know from experience that a ten farad still dimmed my lights. so to push what i have, i thought it would be a good idea to upgrade.
    as well could you tell me were to go to get more info on the matter? i am well read on it. i just want to make sure so i don't kill all i have. maybe point me to a new forum. i am very new to this.
    Apr 2008
    let me be the first to apologize to all you numb skulls, j/k.
    thanks.
    Apr 2008
    wiring???
    i have; two 750 rms subs, one 20 farad cap, two dry cell batteries(divided by an isolator), and two htc amps. one amp goes at 600 rms 2 ohms each channel by two channels to my two subs (not bridged at 2 ohms), the other amp is 75 rms 4 ohms by four channels that go to my 100 rms component speakers. what would be the proper way to wire all of this together needing the cap to go to both amps and the batteries to remain isolated?"
    power supply
    using 0 gauge wire; car battery + to isolator, isolator to the second batteries +, ground second batteries - to the car, from second battery to the cap + (fully charged by a resistor before you connect it straight to the battery. leave disconnected from the battery till you have wired your whole system.), ground the - of the cap to the car, + of the cap to a big fused power distribution block (with a handle of the load of both amps.), one 0 gauge down to 2 4 gauge wires, one wire (4 gauge) to a fuse (big enough for the first amp) to the first amp, the other wire to another fuse for and to the second amp. (matching the fuse to the recommended size for the second amp the second amp.), run the remote wire to both amps. run all grounds to a power distribution block and ground to the car securely. file all the paint away from the metal below all grounds on the car. reconnect cap to battery.
    speakers
    Maximum Bitrate Caelric's Avatar
    Sep 2005
    Bellevue, NE
    Quote Originally Posted by halfzack View Post
    Go find yourself a car audio forum, not a car computer forum that has a sub forum that specifically deals with car audio as it relates to car computers.
    And again, if you would like to get help, I recommend not insulting the possible helpers.
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
    Elsewhere
    I merged the OP's threads since they are identical...
    Please make an effort to post in the appropriate forum fron now on.
    How about the Wiki?
    Apr 2008
    by the way sedtc, and all the rest of you. exsuse me for this but,
    "High End Solutions
    This forum is reserved for those users who are looking for the best sound possible. These users have different needs, wants, and desires from the rest of the users on this forum in regards to audio."
    this is the entrance title to this forum. if you read it, my questions were in the right place. dont call it a high end audio forum if it is for only p.c.'s. even if audio is all you want from you car pc. my question is why not just buy a nice deck that interfaces with your ipod like my kenwood? i control my ipod right through my deck never needing to touch my ipod at all. unless you guys have huge E penises the 160 gig would do most just fine.
    Apr 2008
    now, as for why i chose to go here should be taken as a compliment. i went here because all of you seem to be used to dealing with complex wiring, figuring out what wire goes were and dose what. so i assumed though maybe mis judged from reading your posts that this would be a good place to get the information i need.
  1. Wiring question...
    By atikali2000 in forum Newbie
    Last Post: 04-17-2008, 11:21 PM
  2. AWG wiring issue on M2-ATX...???
    By Nazx in forum Newbie
    Last Post: 03-31-2008, 08:03 PM
  3. Replies: 8
    Last Post: 02-14-2006, 07:43 PM
  4. if you designed a vehicle's interior and wiring, how would you do it?
    By stapan in forum General MP3Car Discussion
    Last Post: 12-26-2005, 02:56 PM
  5. Specific wiring schematic 4 Optrex DMC40457?
    By sooty in forum LCD/Display
    Last Post: 07-17-2001, 03:11 AM
