ehm hardcorejuggalo..... PT and digital are 2 different companies...., so the subs aren't in any way the same
@ronjon.... Not totally correct, since besides parrallel or
series, you could also wire in stereo.... Which isn't recommended, but still, it's possible. so if it is actually a DVC 4Ohm sub, yes, it could run in 2,4 or 8 Ohm
@hardcorejuggalo: it isn't recommended to wire the sub in stereo since alighning the input on both VQ's without measuring the output of the 2 channels will result in crappy
sound. And besides that, with your current amp it isn't possible anyways, since it's a monoblock. So in that case, yes, you can only run the sub at 2 or 8 Ohms
