Well that confirms that you will need some sort of switch. And I still think a transistor will be your best bet.
Either that or just throw in a manual switch to "un-plug/plug-in" your input.
When i unplug my cables from the computer to amp. No static, or any strange sounds.
When its pluged in, and my PC is OFF, then I get the static. I dont have a headunit. I only have an amp and carputer.
I have the same problem. I am using an external soundcard. While the pc is booting I get alternator whining/buzzing/clicking until windows starts.
I have a switch to keep the amp off until Windows start but it is still a PITA. What about grounding the external soundcard or PC?
Is there an RCA off switch?
Instead of making a new thread I decided to bring up this one...
OK, so, it's been a few months since I took off the head unit, upgraded carpc, installed amp, sub etc.
But...
I still cannot get rid of that buzzing noise. I tried ground loop isolator - the noise became even louder. I tried to ground the RCA negative to the chassis - didn't help.
It's definitely pc sound card gives this problem because once I unplug rca from pc, the noise disappears. Oh yeah, it's built in sound card and connected to the amp thru 3.5mm to RCA Y-adapter. The pc powered thru inverter and inverter is grounded. However when I power pc from outside there is no noise...
Any help appreciated.
