Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Wiring two dual-voice coil subs to one mono amp
    Newbie venom889's Avatar
    Sep 2006
    I've got two dual voice coil subs I'm trying to hook into a mono sub with two sets of speaker outputs.
    Infinity 1252W (300W RMS) Link
    # 2 or 8 ohm impedance
    Infinity 1600A Link
    # 894W peak output @ 2 ohms
    # 400W RMS output @ 4 ohms
    # 600W RMS output @ 2 ohms
    I'm rather confused on how to hook these up. It's been a while since I've taken physics
    My subs are 2 or 8 ohm, but dual-voice coil. Does this mean each hookup (each voice coil) is 1 ohm or 4 ohms? Will I have to hook these subs up in parallel?
    Help please!
    EDIT: Manual Link Scroll to 1600a
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    wire the voice coils in parallel (neg to neg, pos to pos) on both subs. then wire the poss. of sub one to the + on the amp and the neg of sub two to the - of the amp. then take the remaining terminals of each sub and wire them together. so it goes:
    http://www.bcae1.com/srsparll.htm
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Mar 2008
    Each voice coil is 4 ohms.
    If you wire those in parallel, it goes down to 2 ohms.
    If you wire those in series, it goes up to 8 ohms.
    Since you have 2 subs, you can wire it a couple different ways.
    I think the best way to wire it would be to go for a 4 ohm load.
    To get that you wire each of your subs to an 8 ohm load, then wire them in parallel together to get a 4 ohm load.
    See this diagram.
    You will be under powering them by a bit, but it is the best you will get with that setup.
    Variable Bitrate hailrazer's Avatar
    Mar 2008
    Columbus, Georgia
    When it says it is a 2ohm or 8ohm speaker what that means is each voice coil is 4 ohms.
    And unlike the poster above me the correct answer is:
    If you wire them in parallel 4(4)/4+4 = 2ohms
    If you wire them in series 4ohms + 4 ohms = 8ohms
    http://www.bcae1.com/spkrmlti.htm
    Mar 2008
    Quote Originally Posted by hailrazer View Post
    What are you talking about?
    He has 2 subs not 1.
    Each sub is wired to 8 ohms.
    You then wire the two subs in parallel for 4 ohms.
    I am right, you are wrong.
    Mar 2008
    Columbus, Georgia
    Quote Originally Posted by ArcaneDreams View Post
    I think you are missing the point I was making . You said
    If you wire those in series, it goes down to 2 ohms.
    If you wire those in parallel, it goes up to 8 ohms.
    That is completely backwards. Series adds ohms . Parallel lowers ohms
    And I know he has 2 subs. 2 subs with 2 - 4ohm voice coils on each one.
    I was just pointing out how wiring the two voice coils gives him either 2 or 8ohms on each speaker
    Mar 2008
    oops.
    I transposed my words.
    I got it right here though
    fixing.
    Mar 2008
    Columbus, Georgia
    oops.
    fixing.
    I knew you knew what you were talking about I just wanted to make sure the original poster had it figured out.
    Mar 2008
    Dec 2004
    Los Angeles Ca
    See this diagram.
    that will get you the same exact impedance as what i posted... just the other way around :-)
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. using a 1 ohm amp to power 2 ohm subs?!
    By atlantamane in forum Car Audio
    Last Post: 10-27-2008, 02:42 AM
  3. Amp Wiring Kit
    By Pudge in forum Car Audio
    Last Post: 12-26-2006, 04:19 AM
  4. Using existing amp wiring for OPUS/Inverter?
    By SwapMeet in forum Power Supplies
    Last Post: 11-12-2004, 04:39 PM
  5. Recommendations for amp wiring kits...
    By hd54321 in forum Car Audio
    Last Post: 08-17-2004, 07:02 PM
