Results 1 to 3 of 3
Thread: Reduce onboard audio noise
    Feb 2007
    I've got a liddle board all set up and good to go except - the audio quality out of it is a bit rubbish! Basically building my own car PC on the cheap - using a board off eBay and parts from Maplins/the computer shop I work in.
    Great audio range and power from the thing, it's just it suffers from unclean audio. It's not electrical noise from the power supply per se; it's more like hard-drive noise and "CPU noise", basically anything that is drawing power/processing on the board. So in between songs you hear a steady hiss and rhythmic ticking/clicking noises as it reads from the disk or processes information.
    Obviously I can't modify the motherboard to reduce this, muting all analogue inputs has no effect, so I was wondering, would a USB sound card solve my problems and isolate the noise? I can't use PCI solutions; the space just isn't there.
    any suggestions welcome, I really can't WAIT to get this thing installed :P
    Variable Bitrate rgarjr's Avatar
    Jan 2008
    Covina, CA
    Well i think using a usb sound card will clean up the noise a bit but it can still be introduced.
    My carpc worklog
    Feb 2007
    Yeah I expect so, I just figured putting as much distance between the board and the sound device as possible would help
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Poor man's guide to remove power supply noise from audio
    By Gip in forum Hardware Development
    Last Post: 05-20-2010, 07:05 AM
  3. Bloomin' alternator whine
    By Vodkapete in forum Car Audio
    Last Post: 05-03-2007, 06:25 PM
  4. Got rid of BUZZ noise!!
    By bleunetizen in forum General Hardware Discussion
    Last Post: 10-30-2005, 08:20 PM
  5. noise in audio
    By Harvester in forum General Hardware Discussion
    Last Post: 10-03-2005, 08:40 PM
