1. Not sure on audio till I see it. Went ahead and picked up that Audigy 2 card. Can tell by the plugs it isn't going to work. There is a red and green plug in front and in back. That tells me it's just an extension. 2 channels per plug (r/lx2, then c/sub)? If I am not mistaken, when you use the 6 channel (5.1), you lose the inputs. The board I'm using now is set up that way. Also a jetway.
2. Going to run dual M2-ATX
supplies(1 in my current system, then ordered a second). One will mount, probably, where the current supply is in the case. That 3.5" drive is going to come out and a 2.5" drive will go in, so I am sure there will be room somewhere. Although, I am interested to see how this system would run Vista Ultimate. Might load the demo version just to watch it.
The second supply will be up front inside my old
radio unit housing(now imon ultrabay) and it will drive everything up front. Then a single gold plated USB cable to bring the front to the back and voila!
Can't wait to try that S3 standby.
