Ok, got the new computer in with the Jetway J9F2 mobo. Playing around with it since I am waiting for the new hybrid drive to come in. It appears you CAN separate the front ports from the back. Here is the breakdown:
Rear (3 ports for 4.1/5.1 surround)
Front l/r
Rear l/r
Subwoofer
Front (2 ports)
Micfront with Noise and ECHO cancellation
Headphones
Now the problem. There is a line in, but only when using the 2 output. So here is what I am going to attempt....
The Audigy 2 for line in, line out for front, rear, and sub. Then the internal
sound for microphone with noise/echo. I am guessing, though, there will be a problem with echo since the same soundcard is not being used for the speakers and the mic. If that is the case, I am going to try using the audigy 2 for line in only. Seems one of these setups should work nicely. I'll let you know. The hybrid drive should be in tomorrow. Have found the location in the new case to mount the m2-atx so it looks like everything is going to be a go.
I also was able to get the second system built using the C137 Casetronic case. Logic Systems tried telling me they couldn't mount an M2-atx and I needed to buy an M3. They didn't look very close. There is a place right in front of the motherboard that is made (specifically I am guessing) for an M2 since it fits perfectly. Some peoples kids.
