Just had my first 5 hour "shakedown" drive (Austin to Dallas) and the Kino-9452-R11 board....hell....the whole computer did fantastic. Well, up until I tried loading the iCar skin onto 1.1.1.6. I was warned it didn't work.....just didn't believe it. Had to pull over and reload SD.
SD seems to be REALLY smart with this board too. Didn't have to change any of the configuration. As a matter of fact, it might be too smart. I like to disable
navigation so I can play around with config while moving. SD decided not to play along. It was disabled, but the GPS still worked! Couldn't believe it.
The
sound using the
onboard realtek ACL833......I would put it up against anything Creative puts out. AND I have my subwoofer back! Woohoo! XM works fine and again, SD was smart enough to know where it was hooked up. Even had record capabilities! Up until the icar incident that is. lol
Now trying to get the front ports working so I can install HD Visteon and possibly HQCT.
Also noteworthy....entire system is running fine on a single M2-ATX supply! I have a second, but I haven't installed it yet.
Edit: Can't say what I am using it for, but the mic portion of the board has noise and echo cancelation built in. It's "ok". Not perfect.
