+ Reply to Thread
Results 1 to 10 of 12
Thread: XM volume too low
    Feb 2007
    XM volume too low
    I recently finished up my JeepPuter and got it installed in my Grand Cherokee. I had decided to go with an eeepc laptop to power everything, unfortunately it only has a microphone input, and no line in input. I have the line out running directly to an Infinity 4+1 channel amp. Audio playing from MP3's or anything else on the computer are loud and clear, but the XM input I have to max the microphone volume to max and enable the microphone boost to get it to the same level as everything else on the system. This makes the already crappy XM quality almost unbearable.
    I'm trying to avoid using a seperate USB soundcard since that would mean I would have to use a USB hub in the back (most of my USB stuff is in a hub behind my "deck"). Are there any quality preamps that are very small and could bring the output of the XM up to microphone levels? I don't know if it made a difference, but I had to install a ground loop isolator between the XM and laptop to get rid of engine noise, even though their on the same ground.
    Dan
    Variable Bitrate rgarjr's Avatar
    Jan 2008
    Covina, CA
    What kind of XM radio u have?
    My carpc worklog
    Feb 2007
    Quote Originally Posted by rgarjr View Post
    It's the standard MP3car XM package
    Variable Bitrate hailrazer's Avatar
    Mar 2008
    Columbus, Georgia
    Mic inputs are mono and you need a stereo input.
    Might want to go with an external USB soundcard.
    Jan 2008
    Covina, CA
    The thing with pre-amps is that it can most likely bring some noise or hum in. Yeah connecting the audio to the mic in isn't a good thing.
    My carpc worklog
    Feb 2007
    Quote Originally Posted by hailrazer View Post
    I thought this as well, so I tested it with a single channel at a time and determined it is in fact stereo sound. The sound is based on the intel HD audio, and the app that it comes with even has a place to choose between line in and microphone in, but it doesn't make a difference on how loud the audio is.
    Feb 2007
    My post at Eeeuser for cross referencing:
    http://forum.eeeuser.com/viewtopic.p...223262#p223262
    Nov 2004
    St Louis
    Its unfortunate that you're experiencing a ground loop. I had the same problem with my XM Commander when I first installed it. I tried several methods to rid myself of the noise including what you've already tried, i.e., grounded together, ground loop isolator, grounded XM PCBoard to Computer and hedf unit, etc. What finally worked was moving the unit and shielding the unit's PCBoard and RCA cables. Yes the XM PCBoard is picking up RFI and its compounded when you use the RCA out (I patched into my FM antenna and used the FM modulator and no engine noise was discernible).
    My recommendation to you is get the external sound card with a decent line in. If that's not an option then bite the bullet and buy some high-end shielded RCA cables (I think I paid $32/pair) and try relocating the XM box to several different locations to find one that reduces the noise picked up.
    All my personal installs have been with TabletPCs and until the most recent an external sound card was out of the question so like you I used the mic in for XM. Out of the three different Tablets I've installed, the output of the XM has always overmodulated (too loud for) the Mic line...hmmm.
    Feb 2007
    Quote Originally Posted by GizmoQ View Post
    The ground loop isolator actually completely took care of the ground loop noise for me. I don't have a head unit, I'm going straight from the XM box to the computer thats 8" away using a 1m cable. The only idea I have is that the ACC line has a slightly different voltage than the line directly off the battery and thats what's causing my issues. The ground loop isolator might just be masking the real problem. I just can't figure out what the deal is with the microphone input.
    Feb 2007
    up to the top in hope for help.
+ Reply to Thread
  1. RR unmutes line in and mic on volume change
    By diosagain in forum Road Runner
    Last Post: 02-07-2008, 11:00 PM
  2. speakers cutting out at low volume
    By Cloud in forum Car Audio
    Last Post: 11-08-2007, 03:13 PM
  3. Volume problem with RR.
    By Outsider787 in forum Road Runner
    Last Post: 08-01-2007, 02:45 AM
  4. Video volume too low
    By reda4 in forum FrodoPlayer
    Last Post: 12-28-2004, 10:40 AM
  5. Ext Apps Volume too low
    By goof in forum Media Engine
    Last Post: 05-09-2004, 06:21 AM
