Results 1 to 3 of 3
Thread: Components not working...please help?
    Sep 2006
    Minneapolis
    i have recently put in a pc and so had to add 2 4channel amps to supply power for my components. To speeding things up and recude the amount of tearing apart of my car i decided to wire the front and rear, but not the center, speakers through the factory wires. All i did was take some nice 12ga or so copper wire and splice it to the wiring harness adapter i got from Bestbuy a few years ago, i then ran the other end of this cable bundle to the amps. I worked of a while but now i am getting almost nothing to these 4 speaker sets(each set is a seperate mid and tweeter). I get only a small weak signal from the tweeters? the car is a 98 Trans Am.......any idea what is happening? Or how i can fix this problem? The amp and all RCA cables have all been tested and are working well.
    Maximum Bitrate boomintrac's Avatar
    Apr 2005
    2hr west of Chicago
    Check the sound card settings, somethings might have gotten switched, or volume attenuated accidently.
    Aron
    Absolutely 100% stock
    Low Bitrate scfountain's Avatar
    Sep 2005
    Southeast Texas
    Have you checked to see if your car has a factory amp? I have a friend with a 1999 Trans AM WS6 and it had a factory amp. If so, you'll need to bypass it in order to use an aftermarket amp.
    Don't hold your farts in! They travel up your spine, into your brain, and that's where you get crappy ideas from!!!
  1. Infill G4 stopped working
    By haiminger in forum Centrafuse
    Last Post: 11-11-2007, 03:54 PM
  2. No USB Devices Working Out of the Blue
    By tbird2340 in forum General MP3Car Discussion
    Last Post: 10-17-2007, 12:21 PM
  3. -DisableWindowHooks not working - 1.1.0.0
    By Indy in forum StreetDeck Bug Reports
    Last Post: 07-31-2007, 09:40 AM
  4. SPV M700 / HTC P3600 not working with Phonecontrol
    By Tracert in forum PhoneControl
    Last Post: 07-13-2007, 11:16 PM
  5. Anyone currently working with 18f2550
    By lez in forum General Hardware Discussion
    Last Post: 11-03-2006, 08:44 AM
