If there's not that big of a difference between the SI and the amp you linked to then I'll go with the one you linked to.
How do they compare?
~ Austin
depend on which amp you go with. if you go with the SI amp then you would just need a 3.5mm mini to 3.5mm mini. if you go with the other amp i linked too you could use a pair of these:
[media]http://www.cablesdirect.com/prodimages/CC399-12_LR.jpg[/media]
or just get a single 3.5mm mini to 3.5mm mini, cut it in half and just use the screw down terminals on the board
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
~ Austin
dunno, only listened to one. one is half the price though :-)
M10k
My Car Pc Install
My Boat Pc worklog
I'm going to go with the SI as I found a couple of the 2nd gen SI's used for $30.
Again, I want to thank you for everything,
~ Austin
So, any idea how (or where I could find out how) to wire the T-Amps to my OPUS 320 Watt PSU?
Thanks,
~ Austin
just get an appropriate plug from radio shack and wire the 12v and neg lead from the opus to that plug and you're done.
M10k
My Car Pc Install
My Boat Pc worklog
Just came across this thread looking for something else. I have pretty much the same car with an amp hooked up to the puter and the stock speakers. I purchased a PHOENIX Gold XS6600. It's about 275 on ebay but it's a 6 channel amp. This allowed me to hook up all 4 stock speakers and use the other two channels for a bridged subwoofer, and it sounds awesome. A lot better than that piece of junk HU. I also got a wiring harness from crutchfield plugged it into the stock wiring harness, soldered the new speaker wires to it, ran em down the passenger side rail of the car to the amp in the hatch. If I ever want to hook the HU back up all I need to do is unplug it. The whole interior comes apart pretty easy. Goto scionlife.com, there are step by step instructions just search the message board.
the op wants an all in one solution that will fit in the dash.
M10k
My Car Pc Install
My Boat Pc worklog
