Results 1 to 10 of 18
Thread: Amp for Scion tC Carputer
    Mar 2008
    Stamford, Connecticut
    I'm looking for a somewhat affordable amp for my 05 Scion tC (stock speakers).
    To be completely honest, I don't know that much about amps, speakers, or sound in general, and I don't really want to learn (I'm aware this might get me flamed)...
    I basically just want to hook up my carputer (the computer is using a Sound Blaster Audigy SE sound card), to the stock speakers in my 05 Scion tC, without degrading the sound quality compared to my stock head unit (and not losing volume).
    I realize I could just buy another head unit with an auxiliary input, but I don't feel that would be a very elegant solution.
    ~ Austin
    P.S. I'm open to buying a used Amp.
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    Quote Originally Posted by AustinMatherne View Post
    Quick learner ey
    Don't think anyone is willing to spoonfeed, or help, for that matter. Especially if you just admitted you aren't at all willing to do an effort yourself.
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
    Mar 2008
    I'm not looking to be spooned (I'm capable of searching on my own).
    All I'm looking for is a suggestion on an affordable Amp that will work with my current setup.
    The reason I don't really want to learn about speakers and so forth, isn't because I don't want to do the work, it's because I know if I do then I'm gonna want to replace the speakers add a sub, etc, etc, etc and I don't have the money to do it. So why torture myself?
    I hope you understand,
    ~ Austin
    Edit: I'm familiar with the Sonic T-Amp (looked into it for my desktop back when it first came out) and I've seen some people talk about it around here (by searching). I know its only 15 watts, isn't that not nearly enough for a car setup?
    Thanks,
    ~ Austin
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    i always suggest the t-amp if you want it in a small space and don't want to have to worry about running new wiring. i believe that it'll give you near stock sound. your stock head unit probably is only putting out about 8 watts rms anyways.
    if you dont mind running the wires and everything look at the infinity/jbl amps, they are pretty well made and inexpensive. should give you plenty of headroom so make sure to set your gains correctly.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Jul 2006
    seattle
    soundstrom 4f400.
    4 channel, about $50 dollar at amazon.
    working great on my stock speaker setup (at least better then the output of my stock head unit)
    Mar 2008
    Quote Originally Posted by scott_fx View Post
    This was exactly the kind of reply I was looking for.
    I'm surprised the head unit only puts out that many watts.
    Space is very minimal for this install so I'll look more into the T-Amp (but I'll give the infinity/jbl a look to).
    Thank you,
    ~ Austin
    Edit: So you're saying I can just hook the Amps up to the speaker wiring running from the stock head unit?
    Am I correct in assuming I need two T-Amps 2x2 Channels = 4 Channels? and that I'll just use an adapter that will split the rear output from my sound card into two channels and I do the same with the front output?
    Also, does it matter what channels are running on the Amps? For instance both front channels on one Amp and the rear on the other, or left and right?
    Is the following digram correct?
    Thanks again,
    ~ Ausitn
    Dec 2004
    Los Angeles Ca
    you could also try two of these if you have enough power on your psu (or maybe get a second dc-dc psu):
    http://cgi.ebay.com/2-15-watt-4ohm-T...QQcmdZViewItem
    actually... you would run into similar powering issues regardless of which amp you used. you can just hook these amps straight to the 12v car battery.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Mar 2008
    Are you sure I cant run the two T-Amps off my OPUS 320W PSU?
    I'll be using the 320W OPUS to power the following system.
    Motherboard: DFI nForce4 Ultra-D
    Processor: Underclocked AMD Opteron 165
    Video Card: XFX GeForce 7100GS
    Sound Card: Sound Blaster Audigy SE
    Hard Drive: Seagate 300GB 7200.8 IDE
    Display: MP3Car 2008 7” Transflective
    GPS: USGlobalSat BU-353
    USB Bluetooth Adapter: D-Link DBT-120
    USB Wi-Fi Adapter: D-Link DWA-556
    Microphone: Andrea Electronic Superbeam
    ~ Austin
    Dec 2004
    Los Angeles Ca
    you very well could, just make sure. I'll let you do the legwork on that :-)
    ~ Austin
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Mar 2008
    I can do that.
    Just to clarify, all I need for the Amps (besides running power to them) would be two (in the right length)
    3.5mm Mini-Stereo Male to Two RCA Male Speaker Cable
    Thanks again for all your help,
    ~ Austin
  1. Replies: 20
    Last Post: 03-19-2006, 05:01 AM
  2. Who is using their carputer straight to an amp?
    By verbal kent in forum Car Audio
    Last Post: 02-11-2006, 11:30 PM
  3. Questions re: my Carputer amp, EVIC, etc.
    By vettejock99 in forum Car Audio
    Last Post: 09-07-2005, 04:39 PM
  4. Replies: 9
    Last Post: 08-07-2005, 12:27 PM
  5. seperate amp for carputer
    By schrodos in forum General Hardware Discussion
    Last Post: 11-12-2000, 10:00 PM
