Results 1 to 9 of 9
Thread: Need tips for eliminating HDD noise
    Constant Bitrate coffeejolts's Avatar
    Jan 2006
    Duluth, GA
    I am getting a fair amount of HDD noise through my speakers. I have an Asus Pundit MB using onboard sound (SoundMax). The HDD noise drives me nuts, especially if I'm playing a quiet song. The harder the computer works, the worse the noise gets. The engine speed does not affect the noise, plus I have a nice solid ground point, so I don't really think grounding is the issue here.
    I did read where some people had success eliminating HDD noise by grounding the PC chassis. I tried this, but it did not help. I also tried using a cheap usb sound card instead of the onboard sound. That didn't help either. My next step is to try using an Audigy PCI audio card that I have laying around. Is there anything else I should try?
    Jul 2006
    seattle
    did you try ground loop isolator?
    something like this:
    http://www.radioshack.com/product/in...entPage=search
    Jan 2006
    Duluth, GA
    Quote Originally Posted by skuller View Post
    No, I did not. Everything I've read says that you should not need one if you do a proper ground. When I have some time, I'll hook up a AC PSU to the carputer and see how it sounds. If the noise is gone, I'll have a good indication that it's a grounding problem.
    Jan 2006
    Duluth, GA
    Ok, I just tried an Audigy 2 in place of the onboard sound. The HDD is much fainter now, but it's still there.
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by coffeejolts View Post
    The easiest thing to do is buy a Ground Loop isolator, it will remove the device whine 100%. If I were you though, I would get the isolator from Best Buy. http://www.bestbuy.com/site/olspage....=1122655296186, it is the only one I have used that does not muffle sound quality, infact it improves it. I use an isolator on the front, rear and sub. The price ($17.99) is a bit much, but like I said it does not mess up sound quality. Try Ebay'ing it, I got lucky with mine and got 5 of the units for $20.00.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
    Jan 2006
    Duluth, GA
    I broke down and bought one of those isolators (IEC GLI) off of Ebay. It came to $11 including shipping, so not too bad. In the meantime, I'm going to keep fiddling around and see if I can't solve the problem without the GLI.
    Newbie visenri's Avatar
    Dec 2005
    You have to check windows sound mixer and make sure all unused audio sources are in mute (mainly mic, aux, line in, etc).
    In 90% of cases mic input picks up noise from HD and other sources, it's very sensitive, this is norlmal. Just mute all unused audio sources.
    WV GOLF V sportline with sempron 3100 under the seat.
    My own software: http://www.solocarputer.com/phpbb2/viewtopic.php?t=7175
    My carputer: http://www.solocarputer.com/phpbb2/viewtopic.php?t=6913
    My web: http://visenri.webatu.com
    Jan 2006
    Duluth, GA
    Well, the GLI "fixed" the issue- or should I say "hid". I don't notice any difference in sound, but I wish I could have eliminated the noise without the GLI.
    Jun 2005
    chicago, Illinois
    The only way I think is possible is to put ferrite chokes over each of the cables of the device that is creating or receiving the noise. Its worth a shot.
    PROGRESS:
  1. Hard Drive Issues in a Vehicle Computer
    By DarquePervert in forum The FAQ Emporium
    Last Post: 02-23-2008, 02:35 PM
  2. HELP - resume issue - HDD broken?
    By quinrod in forum General Hardware Discussion
    Last Post: 01-28-2007, 09:40 AM
  3. SXRC.... Engine Noise Problem
    By bird in forum Car Audio
    Last Post: 05-30-2006, 01:21 AM
  4. Troubleshooting: NOISE
    By RedGTiVR6 in forum Car Audio FAQ
    Last Post: 03-26-2005, 11:31 AM
  5. HDD gone bad?
    By VanMan69 in forum General Hardware Discussion
    Last Post: 08-07-2004, 06:55 AM
