Results 1 to 8 of 8
Thread: protect light is on my amp
    Apr 2008
    i need help... i have a 300 watt Jensen amp and 2 12in insignia subs. my amp was workin good for about 1 week and then me and my bro hooked up a kenwood 600 watt amp to them to see if it would work. but when we hooked my old amp back up the protect light was on. i was wonderin if anyone has any suggestions, i would really appreciate it.
    Variable Bitrate dMand's Avatar
    Oct 2007
    The Evergreen State, Washington
    open your speaker box, check all the wires to see if the positive and negative wires have somehow come in contact causing your amps circuit protection to light up.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    sounds like an impedance problem. how did you wire the two subs to the amp?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Apr 2008
    they are unbrigded right now. I had them brigded when it was working properly.
    Dec 2004
    Los Angeles Ca
    we need to know more. specs on the amp, specs on the sub (voice coil amount and impedance)
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Apr 2008
    Key Features (AMP)
    Amplifier Type: Dual Channel
    Bass Boost With Bass Boost
    Bridgable
    Power Output:
    RMS Power at 4 Ohms75 W x 2
    RMS Power at 2 Ohms100 W x 2
    Performance:
    Bass Boost Frequency = 45 Hz
    Other Features
    MOSFET amp Yes
    subs are 12in 400 watts 200 RMS
    Jun 2005
    chicago, Illinois
    There are only 2 possibilites: wiring issue or equiptment failure.
    If you have a meter check the impedances of the speakers that they are correct and not shorting out.
    Did you accidentally wire in the power wires incorrectly or backwards at any pont when you were reinstalling the amp? Doing that on some amps, even for a sec, can destroy a good working amp.
    PROGRESS:
    Mar 2008
    New York
    Simply put, I had this issue when the positive and negative wires on one of my speakers touched each other. What happened was that somehow I broke the thing on the speaker that holds the two terminals for the speaker wire.
    I'd try disconnecting each speaker wire from the amp, one at a time, and by process of elimination, see which speaker is causing the protect light to come on and then start by checking the connection to that speaker and follow the wire back to where it connects to the amp looking for problems with that wire.
  1. Replies: 38
    Last Post: 11-30-2010, 06:04 AM
  2. Unusual amp shut off problem....please help!
    By mike40370 in forum Car Audio
    Last Post: 12-05-2007, 05:13 PM
  3. Amp running hot...??
    By Emerica2843 in forum General Hardware Discussion
    Last Post: 02-08-2006, 06:40 PM
  4. Amp running hot...??
    By Emerica2843 in forum Car Audio
    Last Post: 01-29-2006, 08:29 PM
