Results 1 to 5 of 5
Thread: Volume control knobs
    May 2008
    Hi all...I'm installing a car stereo in my shop because of its small footprint. I also want to hook up two speakers inside and two outside each pair with its own volume control. That way the head unit volume acts as master and then I can control the speakers individually.
    My challenge has been in finding reasonably sized controls. All I could find are these huge in-wall controls made for home theaters. There's got to be something smaller out there. Any help is greatly appreciated.
    Sam
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by ognat42 View Post
    Sam
    how much are you willing to spend? you could use an l-pad or a twistedpear audio stepped attenuator
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    http://www.mp3car.com/vbulletin/1076188-post5.html
    ^^That will work if have amplifiers, but if you are going through the headunit amplifier there are controls called fader.
    May 2008
    thank you all for the replies. I'm not looking at spending a small fortune but within a $100 is acceptable. Wasn't planning on installing amplifiers, nor did I want to do any soldering . I'll search for the faders. They seem to be just what I want.
    May 2008
    I would not recommend using an in-wall type attenuator.
    There are 2 reasons: (without going deep in technical crap)
    1. Car stereo gear is simply not robust enough to handle the continuous use when feeding a resistive load.
    2. Most inwall VCs have a shared ground path, most car stereos have to be 100% isolated.
    If size is the only criteria, you might want to find a good brand name micro system. It is going to way more stable, have a decent remote, likely better sound, deal just fine with inwall VCs, easy to add subwoofers should you get the urge, etc...
    HTH!
    Luke
  1. Change behaviour Volume control
    By DbXL in forum Centrafuse
    Last Post: 07-09-2006, 12:09 PM
  2. Roadie Volume Control
    By tjp12100 in forum FrodoPlayer
    Last Post: 06-21-2006, 04:30 PM
  3. Replies: 3
    Last Post: 12-10-2005, 02:12 AM
  4. Volume control in Xenarc 700TSV
    By BMW-7 in forum LCD/Display
    Last Post: 04-07-2005, 12:08 AM
  5. hardware volume control
    By ODYSSEY in forum General Hardware Discussion
    Last Post: 04-20-2001, 11:43 AM
