Results 1 to 10 of 20
Thread: stock with no rca's how do i hook subwoofers
    May 2008
    Unhappy stock with no rca's how do i hook subwoofers
    when it comes to this everybody talks about if your amp has a high level imput
    ---------------------------------------------------------------------------------- i am trying to spend no more money than i areddy have
    This is my first setup i am trying to install
    1.2 directed audio 12" 1200 watt subs
    2.VOLFENHAG ZX-8100 2 chanle amp 800 watts
    3.power surge protecter
    plzzz help me out if my am has a high level imput tell me what to do if it doesnt than tell me what i can do for 0$
    Jun 2005
    chicago, Illinois
    I dont think I've known an automotive use for a surge protector. What are you using that for?
    If your amp as high level inputs, then you can just input the corresponding speaker lines into the amp. If your amp does not have hight level inputs and only uses RCAs, then you must convert it to low level inputs with the use of a line out converter (LOC).
    PROGRESS:
    May 2008
    i am using the surge protecter so that if to much power goes threw the wireing the fuses on my amp wont blow it will be the surge protecter first and could you plzz take a look at this website and tell me if my amp has high level imputs if so plzzz tell me what to do with them in detail
    http://www.volfenhagaudio.com/amplifiers.html
    May 2008
    i figered out my amp does run high level inputs so could some one tell me step by step how i could hook my subs up this way. What wires do i cut. Witch ones do i tye. Just step by step
    also will it change the sound quality any.
    and if i do it this way will it rewen the rca wire if i ever want to buy and adapter and hook it up the other way
    Jun 2005
    chicago, Illinois
    Drive to the nearest shop that offers car audio installation. Hand over your keys, and open your wallet. Because it appears that you might be in over your head. With limited skill level, knowledge, and understanding of what you need to accomplish, you might end up causing more damage than good. As a result you may end up paying more than double what you had hoped just to fix your mistakes.
    And please dont double post, It's annoying.
    PROGRESS:
    Nov 2007
    What kind of car is it? Does it have a stock amplifier already?
    Maximum Bitrate Caelric's Avatar
    Sep 2005
    Bellevue, NE
    Quote Originally Posted by pancit175 View Post
    What he said!!!
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
    Mar 2008
    lmao at surge protector. I really hope you aren't talking about a spike bar or something haha.
    A FUSE is what protects your stuff from surges..they are made to blow.
    And yes, go read a lot more about installs. You need to educate yourself way beyond the scope of your question posed here.
    Apr 2008
    Bend, Overagain.
    Line output converter, wired to your rear speakers. This is the short answer.
    Low Bitrate pdegameplayer's Avatar
    Jul 2007
    Harrisonville, Missouri
    i believe you can buy a Scosche Line output converter at wal-mart.....
    just a suggestion....
  1. Replies: 7
    Last Post: 03-04-2008, 10:16 PM
  2. recomend me an AMP. stock speakers, no subs.
    By mattress in forum Car Audio
    Last Post: 02-05-2005, 01:18 AM
  3. Replies: 13
    Last Post: 08-22-2004, 04:52 PM
  4. can I hook this up safely ?
    By E-nigma in forum General Hardware Discussion
    Last Post: 12-09-2003, 11:31 AM
  5. Need some help with sending audio to stock amp
    By orangewhip in forum General Hardware Discussion
    Last Post: 09-04-2003, 01:21 PM
