Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: USB SQ Sound Card battle - Consumer level
  1. #11
    Tainted Love Cris's Avatar
    Romania
    I actually have a USB Hercules Muse LT card now that I got for testing and it doesn' sound bad...I'm assuming the NX2 would sound much better...
  2. #12
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    I had the NX and X-Fi, and what sounded the best was both of them together! Since the X-Fi is very limited on its I/O options, I went with the NX at first. The SQ of the NX is very good, but I really liked what the X-Fi Crystallizer did for my mp3's. So, I decided to run the output of the NX into the input of the X-Fi to be able to use the Crystallizer function (using the X-Fi in standalone mode, where it's not connected to the PC via USB at all). I had the X-Fi mounted on my console and used it as my main volume control. It sounded awesome.
    One thing to consider though is to use the X-Fi in standalone mode, you have to supply it with 5 volts in some other way than from your pc's USB port. If the X-Fi is plugged in to a USB port, standalone mode does not work. I tapped into my cigarette lighter line with a 5v resistor and got everything all nice and neat and tucked away. It worked very well and sounded awesome.
  3. #13
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Quote Originally Posted by Cris View Post
    So, you think it's a better ideea using the 7.1 that the plain stereo? I'm asking because, first off all the sound stage in my car could do for much improvement, and second because I'm afraid that in 7.1 the NX would cut the frequency to the "satelite" speakers too high...or is this adjustable via software?
    Yes, I double checked and you should be able to adjust the filter frequency.
    The only thing I do not see in the manual is the "THX console". If it does not have this, it does not have the time alignment/speaker distance adjustment. Someone who owns the card needs to verify this, because that is the ONLY advantage to using this card in 7.1 mode IMO, otherwise there is no clear benefit.
  4. #14
    Romania
    I see.
    To my knoledge the 2NX has 2V preaout. What about the Transit, how many V doaes it have?
  5. #15
    Romania
    Still undecided between the Transit and the 2NX... I'm also contemplating with the idea of using it's optical output into an Alpine processor with the RUX controller...but again...don't know which one...
    Also, does the Audigy 2NX support the ASIO drivers?
  6. #16
    Romania
    After much debating on which USB card is better I got the Audiotrack Prodigy 7.1 PCI
  1. usb sound card for audio tuning
    By Perrosky in forum Car Audio
    Last Post: 11-07-2007, 04:26 PM
  2. USB Sound Card doesn't power sometimes...
    By n0irsmurf in forum Newbie
    Last Post: 05-02-2006, 07:10 PM
  3. Sound card : PCI vs USB help please
    By AyrtonSennaD in forum Car Audio
    Last Post: 02-26-2006, 10:01 PM
  4. USB Sound Card Option
    By LowLux in forum Car Audio
    Last Post: 11-23-2005, 11:42 AM
  5. Trust 5.1 External USB Sound Card 510EX, any good?
    By FociMan in forum General Hardware Discussion
    Last Post: 06-26-2005, 06:16 PM
