Results 1 to 10 of 13
Thread: Alpine PXA-701 / 700: DIY remote control & PC control
    May 2004
    UK
    Just an early post to share some work on remote controlling the PXA-70x Multimedia controllers.
    Target
    For my new install, I have been looking at no headunit. Like many, this has led me down the PC optical > Alpine PXA700 route.
    I am also looking to limit the amount of boxes/displays/controllers to a minimum, especially 3rd party, on show.
    The RUX controller is therefore being altered to be a "display" only device, within an overhead console. The display will be behind a tinted screen, and will help maintain the "factory look".
    Remote controlling
    For some time, I was going to "hardwire" the micro switches of the RUX PCB. This would create a lot of wiring within a tight space however.
    Time for some good news:
    The RUX does not work on a single data bus i.e. every function (display and switches) working off an unknown word protocol. Instead, the RUX uses basic resistor ladders.
    This explains why the unit uses a 13 pin connector. As you can all see, this creates opportunities!!
    Ideas for implementation
    I'm currently working on the following ideas:
    1) Build a "passthrough box". This would connect to the PXA and the RUX.
    2) Add additional switch panels. Using an exact replica of the resistor ladders, I shall add a couple of switch panels. (My T5 Caravelle has three rows of seats and 2 displays). As these switches are ladders in parallel, there is no real limit. Not all boxes need be the same of course. I'm looking to have 1*full controller for programming, and 1 / 2 "lite" boxes for typical "user" operation.
    3) I shall also remote control these switches for PC control. I'm going to do this by using optocouplers controlled by a Phidgets USB device and girder.
    PC control will allow some user friendly displays of my 6* user presets - displaying the settings and intended uses - music, movies, driver only, centre screen time alignments etc
    Needless to say, you could also make an IR version...
    Encoder
    More work to do on this. Encoders don't like parallel operation typically.
    I have limited time (don't we all) - so may not be able to do much more than share the idea and circuit diagram for now - but will obviously try...
    _
    Mar 2004
    Little Elm, Texas
    So this will all be software controllable?
    The way I'm reading it, you're wanting to eliminate boxes....but to do that, you're adding boxes. The RUX is really very thin.
    So you're essentially mounting the display of the RUX one place, then mounting the buttons elsewhere....correct?
    Jan Bennett
    May 2004
    UK
    Hi RedGTiVR6,
    More boxes maybe - and you effectively spot an error in my thinking perhaps!
    For clarity, I don't want an Alpine unit on view. I don't want buttons in my overhead install. What I want is a discreet interior, with a few buttons added in appropriate places - in the same style and illumination as VW.
    Maybe one more box (the passthrough) but hidden..
    Maybe sharing my idea on this forum was a bad one - I get really defensive at times like this
    P.S. With optocouplers as switches, you can mimic a button push, and you can add graphics to the memories describing your settings.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    I actually think this is a fantastic idea, the reason i ditched the h701 was because i hated the cluttered and space ship feel of the rux controller. if i could have gotten rid of that i would have kept the 701.
    a few ideas, instead of using phidgets you could look into fusion brain and have the rux controlled via the computer.
    if you want a more permanent display but hidden, you could get a piece of smoked plexi and get a vinyl cutter to cut out 'buttons' on black vinyl to which youd mount to the back of the plexi. then you backlight it with some leds and use the qprox ic's to create a touch sensitive panel
    Quote Originally Posted by Tony G View Post
    Hi RedGTiVR6,
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    _
    Mar 2004
    Little Elm, Texas
    if you can make the Alpine controllable by the computer, and even show the display via the computer, I'll buy one in a new york minute.
    However, by it's nature, you need the display of the RUX to be visible, AT LEAST for tuning purposes. If you completely hide it, it's pretty much pointless.
    Jan Bennett
    Dec 2004
    Los Angeles Ca
    tuning and volume control. hell, if he could just figure out how to piggy back the volume control then the rux could be hidden
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Aug 2006
    Hi, great idea. Did U get the vol control to work? If so, please tell me how.
    I guess U could just put in a physical switch that desides witch encoder to use (the switch moves the enc_1 & enc_2 wires to another encoder)? I guess U have to put in all the resistors and caps in the extra encoder circuit to?
    Best regards L.
    Aug 2006
    I have just added an extra volume encoder to my C701. I used a 2-pole on-on switch and I cut the #1 and #3 legs on the original encoder and wired those to the switch (state 1) and then wires from where the legs used to be connected to the switch (common) then from state 2 from the switch to the extra encoder. I allso wired the leg 2 on the original encoder to leg 2 on the extra encoder.
    It works great! I can't use them at the same time but I can decide w/ the swich which one I want to use. Now I have to figure out how to implement up/down buttons (steering wheel buttons) together w/ the extra encoder, not that easy afaik.
    Dec 2004
    Los Angeles Ca
    you should def. do a write up about this. I would have def used this technique if i had to do it all over again... i hated the rux!
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Jul 2007
    DrLove,
    Share the love. We would love to see a write up and some pictures to help us out.
  1. How2 control CarPC from key fob....
    By NotchbackVW in forum Power Supplies
    Last Post: 09-21-2007, 06:27 PM
  2. XENARC 700 TSV Remote Control
    By kbreeden in forum LCD/Display
    Last Post: 08-08-2005, 10:18 AM
  3. need alpine remote control
    By snoop in forum Classified Archive
    Last Post: 08-25-2004, 07:07 PM
  4. home theater pc remote
    By hoodlum in forum General Hardware Discussion
    Last Post: 04-05-2004, 08:37 PM
  5. One remote to control them all
    By liquid_smoke in forum Input Devices
    Last Post: 01-22-2004, 10:00 AM
