Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: enhancing sound system
  1. #21
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    the resistance of the wire is doubled, not the total resistance of the speaker
    New System in progress:
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  2. #22
    Variable Bitrate rijndael's Avatar
    Apr 2007
    on Earth
    383 i think you guys are just messin with me...when did i honestly say that the resistance of the speaker changes?
    resistance has to do with energy...not a speaker...use your heads
    Trouble deciding on car speakers? Clicky Clicky
    Speakers: DLS Ultimate Iridium 6.3 Link
    Subwoofer: removed
    Amplifier#1 (Front Stage): DLS Ultimate A4
    Amplifier#2 (Sub) removed
    Carputer: Removed for tablet install
  3. #23
    Jan 2007
    East Central FLA
    Quote Originally Posted by rijndael View Post
    1) If i am wrong and resistance itself does not hurt the speaker...please let me know...cause that was one thing i thought hurt speakers...
    2) since the current flowing from the amplifier stays the same (100W is 100W)...doesnt he end up with 100W at 4ohm by doubling the length of wire but with less stress on the amp itself creating less heat and thus longer life of the amp?
    1) Resistance doesn't hurt the speaker. What hurts speakers is overdriving the amplifier. When overdriven an amplifier begins to turn a musical sine wave into a square wave. This causes overheating as well as putting out a lot of power at frequencies not intended (a pure square wave would have an infinite frequency spectrum and a 100% duty cycle on the speaker - it could never cool down).
    2) Assume a speaker with 2-Ohms Resistance. The wire leading to it will likely have less than 0.1-Ohm Resistance, resulting in the amp 'seeing' 2.1-Ohms. Doubling the length of the wire then results in the amp seeing 2.2-Ohms (the speaker didn't change). A potentially nasty side effect would probably be induced by too much wire - coiling a wire would cause unwanted inductance - resulting in a low-pass filter effect.
  1. Sound system recommandations?
    By yaniv in forum Car Audio
    Last Post: 02-26-2008, 11:05 AM
  2. Has anyone installed a Dell SX270 wintha sound system?
    By amccoy00 in forum Power Supplies
    Last Post: 12-07-2006, 08:28 PM
  3. Newbie Sound System
    By chris51122 in forum Car Audio
    Last Post: 08-02-2006, 07:50 AM
  4. got sound?
    By masch in forum Newbie
    Last Post: 11-17-2003, 10:01 AM
  5. How do you get sound in to your system???
    By DaPyro in forum General Hardware Discussion
    Last Post: 02-28-2000, 01:10 AM
