An amp wiring kit usually consists of power wires, 4 gauge or 8 gauge, and a dual RCA cable for two channels. That is all you will need to run your subs. Be sure to get the right size power wires though. If you are using all four channels, get a Y-adapter to connect the long RCA cables to both front and rear channel inputs.
LinkBack URL
About LinkBacks
