Results 1 to 10 of 10
Thread: FIRST POST!! 4 channel amp + mono sub amp
    Apr 2008
    Lightbulb FIRST POST!! 4 channel amp + mono sub amp
    OK,so i've seen the diargams on how to hook up carputer to 5 channel amp and thru headunit, but i guess im kinda in a different categorey. I already have a sub amp, and am looking to set up with a 4 channel amp., and loose the headunit. Since it is a mono channel on the sub, wouldnt i just need a 3.5mm (1/8") Male to RCA Mono cable for the sub, and the regular stereo RCA cables for the others, since i wont have a center channel, its basically a 4.1 setup minus the center. Am i correct??
    Mar 2008
    Just get the 3.5mm to RCA for everything.
    So you would need (3) 3.5mm outputs on your PC (which is common).
    1 RCA to your Mono amp, and 2 RCAs to your 4 channel amp.
    Newbie rybitski's Avatar
    Apr 2008
    Virginia
    or you could just buy some of these splitters:
    $.25
    $.20
    http://futurlec.com/Audio-AV.shtml
    so buy 4 rca splitters and one mini jack to rca all for a little over a dollar.
    + shipping
    on that site there is a flat rate for the first $10 or something so stock up on those connectors that is the cheapest place you will find them. plus they are very handy.
    Apr 2008
    Virginia
    Thumbs up
    nevermind, they lowered their shipping charges:
    * Standard Post
    * For orders up to US$29, Delivery Charge - US$4.00.
    * For orders US$30 to US$49, Delivery Charge - US$6.00
    * For order US$50 to US$99, Delivery Charge - US$9.00
    * For order US$100 and above, Delivery Charge - US$14.00
    so you will spend ~$6 total (if that is all you buy) opposed to around $5 a cable as suggested above. (unless you already have some lying around.
    Mar 2008
    That first one would be the one he needs, however it is bulky and may not be useful. Since the 3 outputs on the back of a PC are close together, it is almost impossible to get them all to fit.
    Plus he would still have to buy the standard RCA cables in addition..so no real price difference there.
    And why in the world would he want the RCA splitters? He can just go straight from 3.5mm to RCA.
    Apr 2008
    Virginia
    Sorry, I was assuming that rca cables are something people have lying around from dvd players and what not (maybe this is just me, but I have boxes....)
    Any this is why he would need splitters:
    they are just using a cable splitter.
    Although, you are right it would be bulky. If it is in the trunk though what does it matter (assuming it is in the trunk.
    Mar 2008
    If your audio card is worth anything at all, instead of having one output from the audio card, you could have several.
    Doing it the way pictured above will only give you 2 channels. Left and Right. No Front and Rear.
    So just take part # 3 in your illustration, and replace them with a 3.5mm to RCA, then plug each one in a different output on the audio card.
    Apr 2008
    Virginia
    I was just saying not everyone has an audio card (personally I am using onboard).
    Although not as good the multiple outputs are not always available.
    to sum it all up if you already have RCA cables buy the .25 cent piece and save some money, if not then dismiss my advice.
    Apr 2008
    re
    right i understand the splitters and front back left and right, the only issue i have is the sub. do i need to go with a stereo splitter, or just go with a mono rca plug??
    cables are not a problem, i can get as many as i need....
    i would actually go with this splitter instead..
    May 2006
    Calgary, Alberta
    For the sub you'd get a 3.5 - RCA and run it from the sub/center output of your sound card. Then figure out which side is your bass and plug that side of the RCA cable into your subwoofer amp. If it has a dual RCA input, then get a Y cable to plug it in both spots.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  1. Bass channel not loud enough
    By spoonraker in forum Car Audio
    Last Post: 01-14-2007, 10:18 PM
  2. Replies: 67
    Last Post: 10-15-2006, 09:35 PM
  3. FS: JL Audio 250 Watt Mono Channel Amp
    By j4yj0hn in forum Classified Archive
    Last Post: 02-05-2005, 02:19 AM
  4. Replies: 3
    Last Post: 05-10-2004, 03:58 PM
