i think ytou need further isolation there can only be 1 of three bad parts
bad/loose cableing, bad horn, bad cableing to the amp/bad amp
test this by moving the wires from the big horn side of the amp (lets call it outputB , known good side (everything work side) outputA) over to outputA (after removing the [A] speakers if you get sound then you know that everything past the amp is good on side [b] of the wiring, if you dont get sound further isolate by unhooking the large speaker from the small and running single lines to the amp
just isolate and youll find your answer
LinkBack URL
About LinkBacks
