Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 62
Thread: System Help (High End Audio System)
  1. #31
    Newbie Ianaconi's Avatar
    May 2008
    Brazil
    Quote Originally Posted by Machinehead View Post
    I'm running the M-Audio Firewire 410. I haven't done any apples to apple comparisons to know if I'm losing SQ by converting to RCA. I would think that it would be minimal if any.
    I am not currently doing software tuning at the moment, but I'm planning on it. I'm still trying to shake out bugs to get everything else working 100% of the time.
    Awesome! How do you think it compares with the Delta 1010LT?
    I saw your card has 8 channel outputs, which would be perfect for me. Can you please tell me the rest of your system?
    Thank you very much!
  2. #32
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Quote Originally Posted by Ianaconi View Post
    I believe it very comparable to the Delta 1010LT, similar internals and so forth.
    I'm running bootcamp on a mac mini. A firewire card was a perfect solution for me.
  3. #33
    May 2008
    Brazil
    Awesome. I was checking the MAudio website, and yours is a more expensive model.
    I am thinking on getting a DELTA 1010LT. But it seems it has a lot of features I wouldn't use.
    Basically all I need is a GREAT SQ soundcard with 8 RCA outs or with regular outputs that I could use cables to convert to RCA. I need to be able to control my 3-way frontstage actively and my 10" sub also.
  4. #34
    _
    Mar 2004
    Little Elm, Texas
    Parts Express has them. Radio Shack does as well.
    I said high end, not $4.99...
    And while the quality of the sound card is important, when you're talking about an install on the level of competing in IASCA finals, then ABSOLUTELY YES the quality of the cable is VERY important.
    NOT to be confused with spending thousands of dollars on cables mind you....
    Jan Bennett
  5. #35
    _
    Mar 2004
    Little Elm, Texas
    I would also take a look at the USB/FireWire/PCI sound card list that Durwood worked up. there's a lot of good information in there.
    Jan Bennett
  6. #36
    Jun 2007
    Quote Originally Posted by RedGTiVR6 View Post
    Other than Radio Shack doesn't sell anything for $4.99 they mark it up to $19.99
  7. #37
    _
    Mar 2004
    Little Elm, Texas
    exactly....it's still a crappy cable.
    the only half way decent one I've seen is one that Monster makes for the iPod.
    Jan Bennett
  8. #38
    May 2008
    Brazil
    I will make all the cables myself, with Eichmann Bulletplug Copper conectors on the RCA side, and some good quality connectors on the soundcard side too.
    I will look in Durwood list to see if I can find a nice model.
    So far I kinda like the Delta 1010LT.
    Thank you so much for all the help so far guys!
  9. #39
    May 2008
    Brazil
    Some options I am trying to decide on:
    - ASUS Xonar D2/PM (my favorite so far - ASIO compatible / Comes with 3.5mm to RCA adaptors / Pretty great componenets - any opinions?)
    - MAudio Delta 1010LT
    - Auzentech X-Fi Prelude 7.1 (possibility to upgrade OPAMP in the future)
  10. #40
    May 2008
    Brazil
    New System Idea:
    Case: VoomPC-2 Enclosure - u$90
    Power Supply: M2-ATX-HV 160w - U$90
    MoBo Mini ITX: JetWay J7F2WE2G-OC-PB - U$230
    Memory: G.SKILL Extreme 1GB 240-Pin DDR2 SDRAM DDR2 533 - u$20
    HD: Western Digital Scorpio WD1600BEVSRTL 160GB 5400 RPM SATA 1.5Gb/s - U$70
    SoundCard: ASUS Xonar D2/PM 7.1 PCI - U$170
    TOTAL: U$670
    Display: Xenarc 700TSV - U$350
    Can you guys give me any input/ideas please?
  1. Replies: 19
    Last Post: 12-04-2004, 06:37 PM
  2. BASIC Stamp question
    By Banderon in forum General Hardware Discussion
    Last Post: 05-07-2004, 09:33 AM
