Results 1 to 2 of 2
Thread: 2003 Camry Stereo
    May 2008
    Unhappy 2003 Camry Stereo
    Hi All,
    I have a 2003 Camry. Recently the CD player (single CD) started making funny sounds when you insert a CD or simply when you press the CD button. It would make a contonous (difficult to explain a sound-:, not sure if I can attach an audio file with the sound here - ) sound like as though something is come off from inside. It would still play the CD if I were sucessuful in inserting the same in by force. I am assuming that it might be cheaper to replace the unit instead of trying to get it repaired.
    Any suggestions ?
    Will any unit fit in or would I need the same OEM unit ?
    Also is it possible to replace the same on one's own or needs professional installation ?
    Thanks in Advance !!!
    Jun 2005
    chicago, Illinois
    Appears that the mechanism for the CD (un)load is going bad. If the problem persists and you would like to purchase a new aftermarket headunit, you can do so with a single din radio or a double din radio (Given you have the appropriate kit). Some dash kits have the option to do either, whereas there are those that only have the availbility to do a single din.
  1. Question on Replacing an Alero Stock Stereo
    By alero in forum General MP3Car Discussion
    Last Post: 09-02-2006, 07:22 PM
  2. Need IPOD Video 60GB Adapter for OEM stereo for 2003 Infiniti QX4..Help
    By Lpandroc in forum General MP3Car Discussion
    Last Post: 04-21-2006, 11:47 AM
  3. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
  4. 2003 Pontiac Aztec Stereo Removal
    By Rafster in forum General MP3Car Discussion
    Last Post: 11-16-2003, 01:49 AM
