Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: bye bye noise
  1. #21
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    Well he did day that they bought the car specifically for competition. I have seen worse done to the structures of vehicles for sound competitions.
    IMO, it is a pro job.
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
  2. #22
    Nov 2007
    Quote Originally Posted by greatwhite View Post
    I wonder if that guy knows he cut a major structural panel out of the vehicle just so he could get speakers in that spot?
    I like good sound too, but not enough to compromise the structure of the vehicle.............
    Looks like a nice wiring job though. Crimp and solder, only way to go............
    To compete in IASCA and MECA they have to follow strict safety regulations. Thus, the area was probably structurally reinforced with fiberglass during the speaker installation.
    [98%]
  3. #23
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Quote Originally Posted by audiology View Post
    Structurally reinforced with fiberglass?
    Ummmm,no.
    Leonardo Da Vinci
  4. #24
    Nov 2007
    Ummmm,no.
    ok... u win.
    [98%]
  5. #25
    Variable Bitrate FPeter's Avatar
    May 2008
    Hungary
    based on a question in an another topic, i write down how i made my pcb-s...
    so, its a very easy method: only a laser printer, smoothing-iron and a special type of paper required, plus the liquid for etching. deskjet and other printers are unusable, only the laser uses a plastic-powder based toner!
    the paper is not a regular printer paper. this is a shiny, but not too thick sheet. like the material of several magazines, like inner sheets of playboy and others. a minimal thickness is required because of the printing, the device might get a jam if its too slim... so some experimentation is required... you should print the circuit on the sheet, than clear the raw pcb board with toothpaste for the first, than with some solvent (like wound petrol from a chemist's). after it, you should lay down the sheet to the board, and put a clear printer paper on them. then comes the hot iron (steaming off). practicing is required here, you should find the point when the toner adheres to the board, but not squashes! after it soaking is required with some soap and water, then gently rubbing. when its clear, there is no paper on the free surface, you should put it to the etching stuff...
    the quality depends on the laser printer (600-1200 dpi required for smaller smd parts), on the paper, and of course the practicing, but this can be learned easily...
    "case": Skoda Superb Elegance 1.8T
    Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
  6. #26
    May 2008
    Hungary
    on the other side, im working on a new DAC... now i have a problem with the remote power on (might be the relay is overheating), but i will solve it...
  7. #27
    Constant Bitrate kwchan's Avatar
    Dec 2006
    Singapore - Smallest country in Southeast Asia
    Are there any USB->Optical adapter that doesnt require driver installation?
    I just need an optical output for my Alpine H700 processor
  8. #28
    May 2008
    Hungary
    Quote Originally Posted by kwchan View Post
    nearly all cheap adapter works without driver installation as standard usb audio device, but they are dummy in this mode, there is no kernel streaming, asio, equalizer, eax support, etc... what is your problem with driver installation?
  9. #29
    Dec 2006
    Quote Originally Posted by FPeter View Post
    I dont think i need those function as my H700 is able to do sound processing like time alignment and equalizer. I just want the audio data to feed into H700 digitally via optical cable.
    I prefer no driver installation as my CPU is rather low end and I dont wish to overload it further with more drivers
  1. Alternator Whine Only With Carputer
    By tbird2340 in forum Car Audio
    Last Post: 06-29-2007, 03:36 AM
  2. Bloomin' alternator whine
    By Vodkapete in forum Car Audio
    Last Post: 05-03-2007, 06:25 PM
  3. Got rid of BUZZ noise!!
    By bleunetizen in forum General Hardware Discussion
    Last Post: 10-30-2005, 08:20 PM
  4. Troubleshooting: NOISE
    By RedGTiVR6 in forum Car Audio FAQ
    Last Post: 03-26-2005, 11:31 AM
