are you using the latest drivers?
Hi,
I have converted my H701 to accept coaxial digital signal and it works great w/ soundblaster soundcards but NOT w/ the onboard s/pdif coaxial out on my Epia CN m/b, the same output works w/ my reciever at home, but not the H701.. Is there different (digital) ways to send s/pdif over coaxial? And can I do something about it?
Best regards L
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
I use 7.00b, I'll do a full re install of windows today to see if it helps.
Stupid question, how do you control the volume when using the digital connection? Can you use the computer's volume controls?
the master volume slider is ignored on most of cards in s/pdif mode, but wave works... we should find or write a small background program that links the wave slider to master and the mute checkboxs, so when the vol +/-/mute buttons are pushed, they moves the wave slider too...
"case": Skoda Superb Elegance 1.8T
Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
Yes you can use it, but I don't, I use the volume knob on my H701 to maximize SNR.
A full reinstall of windows did not help. I'm stuck w/ my bulky SB X-fi card for now.
are you following these steps?
http://www.mini-itx.com/hardware/ac3/
M10k
My Car Pc Install
My Boat Pc worklog
