Results 1 to 4 of 4
Thread: So I buy an amp..
    May 2008
    So I buy an amp..
    And the remote screw was missing. Can I use any screw as a replacement or do I have to get a special one?
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Quote Originally Posted by hoopitup3 View Post
    See if one of the other screws can be removed and fit into that spot on the terminal bus. Then take the screw that fits to your local Home Depot or other hardware store and get one that has the same threads, length, etc.
    If you really want help with stuff, remember that we can't read your mind and guess what kind of amp you have. Or car, or pc or where you live, etc. Based on your statement of the problem, not much meaningful advice can be offered to you.
    ~Jimmy
    May 2008
    Sorry man, Power Acoustik LT 1920/2, 1920 watt max, 440 rms x 2, 370 rms x4.
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    what's up with all the PA amps around here lately?
    Usually the same screws that fit the speaker wire terminals fit the remote wire terminal. As JimmyFitz said, if it does fit, take it with to ACE Hardware (or something similar where you live) Home Depot, or even a lot of times car audio shops will have a whole drawer full of them just sitting in the install bay. That's where I got my replacement when I stripped the screw. Just make sure it's the same thread size, and use a washer.
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
  1. AMP Popping, Hissing, Shutting off...PLZ help?!
    By Dougw133 in forum Car Audio
    Last Post: 12-10-2007, 08:24 AM
  2. Replies: 67
    Last Post: 10-15-2006, 08:35 PM
  3. Need suggestions for where to buy wiring
    By Cruelkix in forum Car Audio
    Last Post: 09-02-2006, 03:04 PM
  4. Amp Shuts Off
    By ElementXofXMusi in forum Car Audio
    Last Post: 07-18-2006, 07:34 PM
  5. Did I buy the right amp?
    By jjh221 in forum Off Topic
    Last Post: 04-10-2004, 06:19 PM
