Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: subs cutting out? i;m not sure why...
  1. #11
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    guys, I think that the OP is not around anymore. He probably took it back to where it was installed and had them diagnose the problem. Good info though.
    I had a similar issue, check all the connections and fuses, nothing was blown, I was stumped. I checked the fuse on the battery again, and found it was not blown, but the connections weren't sound. I replaced the fuse, and haven't had an issue since.
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
  2. #12
    Jun 2005
    chicago, Illinois
    Quote Originally Posted by monkeyracer View Post
    Sometimes with glass fuses, there is a rare condition where the fuse will blow towards the ends of the fuse and not in the center where it is obvious. Also sometimes excessive heat will cause the connections within the ends of the fuse to undo itself in such a way that it still puts out a voltage, but also has an unwanted resistance to cause the amplifier to not perform as it should.
    PROGRESS:
  1. FAQ: What speakers/amps should I go with?
    By RedGTiVR6 in forum Car Audio FAQ
    Last Post: 07-13-2007, 07:43 AM
  2. Replies: 2
    Last Post: 05-25-2007, 10:48 PM
  3. Low-budget SPL Subs
    By SuprchargdMazda in forum Car Audio
    Last Post: 05-24-2006, 02:33 AM
  4. Help hooking up subs and amp? Need advice...
    By jedi7001 in forum Car Audio
    Last Post: 05-17-2005, 01:28 AM
  5. FS: 2 mtx 10 inch subs and 400 watt amp with box
    By xdjxklusivex in forum Classified Archive
    Last Post: 02-25-2005, 03:41 AM
