Results 1 to 10 of 12
Thread: subs cutting out? i;m not sure why...
    Jun 2008
    ok so im going to be honest i have no clue about the inner workings of car audio. i bought pioneer head unit, a phoenix digital amp, and two pionner 12'' subs already in a box. i took them all to Circut City in the begining of january to be instaled. just resently we had a heat wave and i drove down to the shore going around 80mph in 100+ temperatures with the music blasting almost all the way up i have all the variables like bass boost and the max and min balanced out and the amp is set to LPH. the next day i noticed the bass cutting out. it didnt matter how loud i was playing the music but the subs would jsut stop playing for mabye a sec jsut missing a beat then they would continue to play only to cut out a fw seconds later. it also didnt matter how long i played them for. it didnt seem to get worse the longer they were on. i checked the ground and the fuses and wiring seem to be good. i know its not the subs because i got those checked already. so im afriad i fried the amp tht day and thts why the subs cut on and off. here are the specs
    Amplifier:
    Phoenix Digital Chrome
    Model #PD393 - 2-Channel 1000 Watt Amp
    MAX Bridged: 1000 Watts
    RMS Bridged: 300 Watts
    Dimensions: 11" x 2.5" x 9.25"
    Subwoofer (2):
    Specifications for Pioneer TS-W301R 12" 4-OHMIMPP composite cone, urethane surround, 50-150W RMS power range, 20-4000 Hz frequency response Car Speaker TypeComponent, Subwoofer Car Speaker Size12" Nominal Power800 W Passive or PoweredPassive Speaker MaterialComposite, Urethane UPC012562785950
    Headunit:
    Sony CDX-F7710 CD Player
    any help would be much appreciated.
    Mar 2006
    Colorado, but Canadian!
    I would say you blew the sub. Serves you right for making everyone miserable blasting music all day. Grow up.
    1.9in x 2.9in -- 47mm x 73mm
    Vendor - Qube colin's Avatar
    Dec 2006
    Are you missing the deep notes, or is it just skipping at a certain interval?
    Jun 2008
    its not missing the deep notes. it just cuts off for a sec and then will play again. it sounds as if there was bad wiring but i cant seem to find any. thats why i think i fried something. and i hooked the subs up to my frineds car and they work fine on his system so its not the speakers themselves that are malfunctioning
    Dec 2006
    Is there any way you can test the amp on your friends car too? Im assuming you dont have a crossover, just your amp with a low-pass filter? Can you be sure that the filter is set up right?
    Jun 2008
    im not sure. if it is the filter is it likely that i could jsut give out? ive had the system working fine for 6 months now. could the filter randomly go haywire?
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    Sounds like either a bad amp or bad sub.
    The amp has an over current and overheat protection. The amp could have been running too hot and fried something. So now the amp is going into protect mode, then checks and comes out of protect mode, etc. If this is the case, bring the system back to Circuit City. You should still have some kind of warranty on it.
    If the subs voice coils have blown, then the incorrect current will be running through the amp, and it will again go into protect mode.
    Bottom Line: Take it back to Circuit City and have them look at it. They installed it, and it should be under warranty.
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
    Feb 2008
    Check the terminals on the subwoofer and the wire going down into the coil from the terminals. Also... check your connection on the fuses on your amp. I tore EVERYTHING apart in my isuzu rodeo just last weekend of the sAME problem. It was mostly random .. sometimes it would do it turned down, sometimes it would do it when cranked... it would HIT... then just cut off... then come back on after that note isn't needing to be played anymore.
    I looked close at the amp to see smoke by the fuse.. Bad connection, removed it, put it back in tight... problem was gone.
    The Remote wire was keeping the power light on and steady on my sony amp so I had no idea it was a +12v power input issue.
    Nov 2007
    1. Double Check your connections make sure they're secure-- Especially the ground. Might have came loose with the major thumping.
    2. Double check if the impedance is hooked up correctly for the subs.
    [98%]
    Feb 2008
    Maybe, check polarities (+/- connections on your input)... is your amp hooked up to the input with RCA cables? try unplugging one or the other while turned up... see if the problem continues. If connected through High level input, switch + / - of each speaker input until the problem goes away.
    hmm..
  1. FAQ: What speakers/amps should I go with?
    By RedGTiVR6 in forum Car Audio FAQ
    Last Post: 07-13-2007, 08:43 AM
  2. Replies: 2
    Last Post: 05-25-2007, 11:48 PM
  3. Low-budget SPL Subs
    By SuprchargdMazda in forum Car Audio
    Last Post: 05-24-2006, 03:33 AM
  4. Help hooking up subs and amp? Need advice...
    By jedi7001 in forum Car Audio
    Last Post: 05-17-2005, 02:28 AM
  5. FS: 2 mtx 10 inch subs and 400 watt amp with box
    By xdjxklusivex in forum Classified Archive
    Last Post: 02-25-2005, 04:41 AM
