Results 1 to 4 of 4
Thread: USB extension
    May 2008
    USB extension
    The alpine head unit cda-9884e features a full speed usb connection in the back. if i were to add cable to extended the lenght( Female to male usb ends) would it affect the speed or quality of the music or signal it is recieving.
    Constant Bitrate Felix509's Avatar
    Feb 2007
    Lafayette, LA
    USB is a standard and should work at 5m length away.
    Alpine has to go by the standards to call it USB so it would be a safe bet it is okay to use an extension. and you would see no difference.
    Ours is the age that is proud of machines that think and suspicious of men who try to.
    ___________________________________
    Current SYSTEM
    AMD64X2 2.5
    Xenarc
    ZAPCO DSP-6
    ARCAUDIO SE Amps
    Rainbow Profi CS365 & Profi Vanadium 12"
    Jun 2005
    chicago, Illinois
    You really dont have to worry about signal degradation when you are talking about USB. USB uses a digital signal. The most common worries about signal degradation are when you are using analog signals.
    The only major worry you may have is the degradation of the power going through the USB when you extend it, such as when you are connecting a device that requires to be powered and doesnt have its own power supply, ie hard drive.
    PROGRESS:
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by pancit175 View Post
    not true.
    it is an analogue signal at its heart, there is no such thing as digital really. And if the length gets too long, that value of 4.9 that indicated a 1 starts to degrade to 2.49 ish and all of a sudden it becomes a 0 when it shouldnt be. This happens over even short runs because not all USB ports are equal even though they need to meet the standard. Cheap parts have an effect on it too. If it is made to work with a flash drive plugged directly into its port, it can use really crappy contacts and connections, then it will still get above the 2.5 volt mark to make a 1 when it should but it wont be 4.99 like using gold contacts, it might be 3.5v or something, so you cant extend it as far.
    Also the faster the USB connection the shorter the run. 5m is the absolute maximum without an active cable.
    1.9in x 2.9in -- 47mm x 73mm
  1. USB port power dies?!
    By pixelflash in forum General Hardware Discussion
    Last Post: 10-22-2007, 10:26 AM
  2. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  3. 16FT USB Cable Extension, Passive Vs Active?
    By mattress in forum General Hardware Discussion
    Last Post: 05-22-2006, 12:45 AM
  4. Powered Hub, Lots of USB Devices! Will this work?
    By adamharrisuk in forum General Hardware Discussion
    Last Post: 05-15-2006, 12:00 AM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
