Results 1 to 8 of 8
Thread: Tweaters install
    Newbie matty93's Avatar
    Jun 2008
    Aus,Melb,Vic
    Question Tweaters install
    Ok i have a new Clarion CD headunit with 4 speakers installed in my HQ holden project,i want to now install some tweaters,whats needed?
    Thanks,Matty
    When the going gets tough,the tough gets stuffed.
    Jun 2005
    chicago, Illinois
    Besides the obvious: speakers, speaker wire, and a way to mount it.
    You will need crossovers or filters to limit the lower end frequencies going to the tweeters. I would recommend that you replace your front speakers and get a component set for your fronts. It would have most everything you'll need to install it into your car, and in my opinion would be a better sound then just adding the tweeters.
    PROGRESS:
    Jun 2008
    Aus,Melb,Vic
    Thank u very much for your help,ill get on to that.
    Dec 2007
    Yea a component set would make it easier.
    Jun 2008
    Aus,Melb,Vic
    Ok thanks, getting them soon,just got to figure out a brand to go with.
    Variable Bitrate brucedog's Avatar
    Oct 2007
    Philadelphia, PA
    Something else to consider; tweeters can be quite directional - I have seen people mount their component tweets in the door somewhere high on the door, possibly replacing stock component tweets. Most people don't have ears in arms or legs.
    The door location is not so good. The speakers fire in the wrong direction. I consider the right direction to be right at me ears. I bought some Pyramid swivel-mount tweets and put one pair on my dash, one pair above the rear passenger doors, about where the clothes hanging hook is located...
    These particular tweets come with crossover capacitors. I swiveled the mounts in order to hear the best sound. Some were a bit loud, so I used quality L-Pads to attenuate.
    Bought most of my car audio goodies from http://partsexpress.com
    ...Just a thought...see my pictures...
    Happy CarPC'ing!
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    also consider what sort of sound you want, different tweeters have different "sound"
    eg silk domes are a bit softer, metal domes are a bit harsher...
    personal preference really.
    i got some pioneer components for my car ages ago, and mounted them on the dash in the corners.
    what you got under the hood of the HQ?
    I did a conversion for my old VC from the stock to a 253... then after 2 years and $1000's later i gave it away. the guy who did the engine recondition screwed it up big time. and wouldnt admit to something being wrong. was only when my mate who i gave it to pulled the head off.... slightly warped, and blowen gasket (3000km pain full since the reco)
    Jun 2008
    I am really hooked on that site I really love those plye speakers there uber cheap and are better than those 40.00 pioneers from wallmart The pyles really put them to shame.
    [QUOTE=brucedog;1226270]Bought most of my car audio goodies from http://partsexpress.com
    Also the best and easiest place to put tweeters is in the middle of the a pillar and swivel them towards you.
  1. 2006 G35 Install - First one
    By froalskiner in forum Worklogs
    Last Post: 02-28-2008, 04:31 PM
  2. Jagputer Install and story log
    By JagPuter in forum Show off your project
    Last Post: 08-02-2006, 09:48 PM
  3. Tinyxp vs nlite vs sensible install
    By geeky_hawkes in forum WinNT Based
    Last Post: 06-15-2006, 04:55 PM
  4. Starting MM trys to install IntelPROset software?
    By sturmovik in forum Map Monkey
    Last Post: 06-03-2006, 03:20 PM
  5. windows xp install
    By Moneyfink in forum WinNT Based
    Last Post: 03-09-2005, 01:05 AM
