normally the "gain" should be set to the highest level you desire before clipping occurs. but in your case you are using an amplifier that can output more power than your subwoofer can handle, so your gain should be set to limit the amplifier output to less than 500w.
they are very different readings. one is the pre-amp (input) voltage, and one is the speaker (output) voltage.
remember, that 4v rating is not what the HU will put out when listing to music. depending on how alpine rates that pre-amp (RCA) output, that 4v rating is either it's 'peak' output or 'RMS' output. if it's an RMS rating, then it will only output 4v when listening to a constant tone at full volume. if it's a peak rating, then it will only output 4v during musical 'peaks' at full volume. either way it will never output 4v at normal listening levels.
both... in most amps; the "gain" control is a potentiometer, which limits the voltage going into the amplifier. the amplifier itself can reach full volume at a lower input voltage than your HU can output. the purpose of the gain is to limit the input voltage to avoid overdriving the amp (or in your case, to limit the output power of the amp by limiting the input voltage even more).
LinkBack URL
About LinkBacks
