Results 1 to 8 of 8
Thread: what size alternater should i upgarde to
    Jun 2008
    Question what size alternater should i upgarde to
    I have a stereo system in my suv that totals 5000 watts with all speakers, amps and cd player. My lights are dimming if i turn the base up. i was told i need a higher amperage alternater, How do i Know what size to get? or how to calculate amps from watts with dc volts.
    Constant Bitrate insaneramman's Avatar
    Mar 2008
    South Carolina
    Somewhere in a range of 420 amps. I think you'd do better with more batteries.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by kedarganesh29 View Post
    P=I * E
    Where:
    P = watts
    I = amperage
    E = voltage
    5000 = I * 13.5
    I= 370 amps
    You need an addition 130 or so more for car electrical, so 500 amps should do it.
    Want to:
    Jun 2008
    Thanks But can you run 2 batteries in series on the same alternater would it charge
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    No, 2 batteries in series would require twice the voltage to charge them. Two batteries in parallel however, that might work.
    You're still gonna need a huge whacking great alternator though, batteries are just a reservoir, not a source of power.
    Jun 2005
    chicago, Illinois
    Batteries are only able to produce a finite amout of charge before it drains out. The batteries main function is for starting the car, and while the car is running it is used for regulating voltage.
    On the other hand, once the engine is on the altenator is producing the neccessary current to run all of the electronics in the car while recharging the batteries (obviously constrained by the specified amperage output of the altenator).
    If the OP were to just add batteries as suggested, with power consumption of the stated 5000 watts, it would not be able to keep up with the power demands of those higher power components.
    PROGRESS:
    Low Bitrate 20mg's Avatar
    Oct 2007
    chico ca
    a higher amperage alternator will take away from your horse power tho. i amd more of a fan of having 2 batterys
    Jun 2005
    chicago, Illinois
    Question to the OP. Is the wattage that you added up the ratings of the devices at the advertised wattages, or PEAK wattages. Or was the wattages the sum of the true power, or RMS wattages.
    Quote Originally Posted by 20mg View Post
    Very true. Which begs the question you ask yourself, "All show, or all go?"
    PROGRESS:
  1. Slingbox/Slingplayer plugin?
    By Nola111 in forum CF Plugins
    Last Post: 06-11-2008, 05:18 PM
  2. HELP! Please post your LCD Panel Size and model info
    By Splash-X in forum LCD/Display
    Last Post: 01-24-2008, 08:23 AM
  3. MCI error 261 and 263
    By genesis66 in forum Road Runner
    Last Post: 12-21-2007, 02:59 PM
  4. Replies: 0
    Last Post: 01-28-2005, 08:00 PM
  5. Replies: 0
    Last Post: 08-28-2002, 05:23 PM
