Results 1 to 4 of 4
Thread: car audio
    Jun 2008
    car audio
    hi this is my first day on this site, ive installed a itx pc in my bmw e36 with a 8" touch screen and sat nav. i want to retain my stereo for the radio how do i utilise the speaker system in the car, which is used by the stereo, to allow music to be played from the pc. This is my first attempt at car pc so any ideas welcome
    Jun 2005
    chicago, Illinois
    If you have any means of connecting through an auxillary connection or by purchasing a adapter compatible for the deck in your car (if there is one available), that would be the best way to connect to the deck without changing it. Otherwise, your only other option would be an FM transmitter.
    Variable Bitrate brucedog's Avatar
    Oct 2007
    Philadelphia, PA
    Yep, about the only way to connect carpc output to HU is if HU has aux input jacks...
    I have anothe solution, though. You can connect directly, but will need some electronic experience, and maybe a bit of bravery...
    I wanted to input an mp3 player to a boombox stereo that did not have an aux input. So, knowing that the volume control is located at an intermediate stage in the audio amplification, between the radio/cd/tape output and the main audio amplifier input, I simply connected a shielded cable from a jack (new hole drilled in boombox case), soldered to volume control. Plugged mp3 player in, boombox plays music faithfully, sounding good.
    This same approach has been used now for car stereo HU's. Same approach to the simple wiring job. Onloy possible consideration is to be sure not to turn carpc volume level up too high, as it might overdrive HU input.
    Happy CarPC'ing!
    Constant Bitrate Felix509's Avatar
    Feb 2007
    Lafayette, LA
    there are quite a few solutions out there that will replace your cd changer with an Aux input.
    If you have a changer already, it is a simple install. You lose your cd changer, but that seems a good trade for a compute rfull of music. I have done this in my car, but never in a BMW
    it, there are many different companies making these adapters, in fact some allow you to keep your changer and just adds an aux In
    Ours is the age that is proud of machines that think and suspicious of men who try to.
    Current SYSTEM
    AMD64X2 2.5
    Rainbow Profi CS365 & Profi Vanadium 12"
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 09:12 PM
  2. Outputting from car audio head unit to home theater receiver
    By mach5 in forum General MP3Car Discussion
    Last Post: 05-31-2007, 12:20 PM
  3. Car Audio & Electronics this month
    By RedGTiVR6 in forum Car Audio
    Last Post: 05-23-2007, 05:25 PM
  4. Replies: 3
    Last Post: 12-07-2004, 07:34 PM
