The only thing I can think of, if it's not a hardware problem is the software. Did you check for the most up to date drivers. From your description, it doesnt appear to be a problem with the rest of your setup and only with that device (either software or hardware).
In any case, I would recommed that you contact the manufacture's technical support if you have any further problems before you try to return/exchange the one you have.
LinkBack URL
About LinkBacks
