Results 1 to 8 of 8
Thread: humming noise?
    Apr 2008
    humming noise?
    I have a question/problem..
    I have a 02 Audi A6 and today I got my factory stereo out and put in a double din dvd player...
    so everything went good.. im driving.. 30 mins later, theres a humming noise... and its really annoying
    it only stops if you press MUTE or put the volume on 0 or turn it off.. but its always on when the music is playing.
    anyone know why this might be happening?
    with the factory stereo everything is fine, so maybe something is connected wrong or what.. I had a professional shop do it
    Mar 2006
    Colorado, but Canadian!
    a) crappy stereo
    b) ground loop causing interference
    you didnt tell us what kind of hu, so (a) i cant comment on. As for ground loops, the shop could have been (and most likely was) sloppy with the wires and there is spaghetti back there. When wires cross, especially power and signal wires, you get humming/buzzing/whining.
    Does the noise go up when the rpm's go up?
    1.9in x 2.9in -- 47mm x 73mm
    Apr 2008
    Uumm.. not really, the noise doesnt go up when the rpm's go up... not that I noticed
    and the head unit, i really dont know what it is, i think a jensen or something
    Low Bitrate sonneboz's Avatar
    Jan 2008
    Tampa
    wait, you put a jensen in an audi????
    we (audi owners) officially disown you.....j/k
    Apr 2008
    lol.. it was the cheapest one to find, and im kinda low on money at the moment so had to get something
    ... anyone know how to fix this?
    Ge0
    Ge0 is offline
    Nov 2007
    Metro Detroit
    I'll bet my beer gut that you have a grounding problem. I also bet that you used some conversion harness to wire the new radio in.
    Your problem is not likely the quality of head unit you chose. Try disconnecting the main ground of the head unit and relocating it to a known solid metal, unpainted, member of your vehicles chassis. You should at least hear a reduction in noise if not eliminate it.
    You may need to try a few different grounding points before you solve this.
    Ge0
    Apr 2008
    My friend took a look at it earlier and its the speaker cables... the people that hooked them up hooked them up through a RCA cable.. so tomorrow were going to hook them up the other way and see whats going on..
    if it was the ground, it would make a humming noise even when its on mute, right?
    Ge0
    Ge0 is offline
    Nov 2007
    Metro Detroit
    Quote Originally Posted by Daki View Post
    Hooked them up through an RCA cable? WTF do you mean?
    Ge0
  1. Alternator Whine Only With Carputer
    By tbird2340 in forum Car Audio
    Last Post: 06-29-2007, 03:36 AM
  2. Bloomin' alternator whine
    By Vodkapete in forum Car Audio
    Last Post: 05-03-2007, 06:25 PM
  3. Got rid of BUZZ noise!!
    By bleunetizen in forum General Hardware Discussion
    Last Post: 10-30-2005, 08:20 PM
  4. need help with hisssing and humming noise
    By pimpmode in forum PowerVoice
    Last Post: 05-31-2005, 04:37 AM
  5. Troubleshooting: NOISE
    By RedGTiVR6 in forum Car Audio FAQ
    Last Post: 03-26-2005, 11:31 AM
