Results 1 to 6 of 6
Thread: did i fry my amp
    Jul 2008
    did i fry my amp
    hi new peaple help! i installed an amp and woofer all wired right, except when i would turn it up loud the amp would go into protect. it was fine for a while until i turned it up all the way ,it went into protect but this time it stayed on protect for a while ,then when it did come back on there was no sound. come to find out the ground came lose, i tightened it still nothing ,what did i do ?
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    If it's still under warantee, then it's defective.
    Nov 2007
    Does the amp still turn on? if not check the fuses.
    And as for the previous problem it seems like you wired your subwoofers incorrectly thus causing the amp to go into protection mode.
    [98%]
    Jun 2008
    Richmond, VA
    I agree that I think the wiring is done wrong...I would check the connections.
    Owner of three automotive franchises, specializing in electronics.
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Threads merged. Please don't double post.
    Mar 2004
    Florence Yall, BFKY
    Yeah, subs wired in parallel as 1 ohm or 2 on a non 2 ohm stable amp could heat it up quick huh?
  1. Engine Noise due to ground loop or amp?
    By matt11601 in forum Car Audio
    Last Post: 08-26-2009, 09:38 PM
  2. Unusual amp shut off problem....please help!
    By mike40370 in forum Car Audio
    Last Post: 12-05-2007, 05:13 PM
  3. Replies: 3
    Last Post: 12-07-2004, 07:34 PM
  4. Amp setup. Heat concern.
    By d_sellers1 in forum Car Audio
    Last Post: 07-09-2004, 10:58 AM
