MS Paint shows
Anyways, with the VGA box, you will need power so you will need to find one that runs off of 5v or 12v so your PSU can handle it. Run the monitors to the battery directly.
Are you saying all the screens are touchscreens? If so you should have a USB line direct to the mobo, hubs are no good with touchscreens. But with that many, depending on your motherboard you may need a hub, but I would run the one that is going in your dash (8"?) direct to the mobo at a minimum. Same with GPS. Put the GPS puck direct to the mobo, and put the IR thing into the hub.
And I wouldnt use IR. If this is a show car, then you want to control outside too for giggles so get a radio solution like standard RF or bluetooth.
LinkBack URL
About LinkBacks
