Results 1 to 6 of 6
Thread: max power help
    Jul 2008
    London,Oh
    max power help
    I have a 1600 watt mono class d amp and two dual voice coil memphis 12s I have them wired parallel witch gives me a 2 ohm load but to get max power I need a 1 ohm load and you can't bridge a mono block cause they go into a single inside the amp even tough it has two speaker inputs on the out side so how do I get a 1 ohm load
    Nov 2007
    what's the ohm load on the subwoofers? dvc 4's or dvc2's? if the subs are dvc 4ohms then wiring them all in parallel should give u 1 ohm.
    btw, do you have the brand/specs of the amp?
    [98%]
    Jun 2005
    chicago, Illinois
    The amplifier is already bridged, you can't bridge it any further.
    Like audiology was getting at, the only conditions you can get your 2 speakers wired down to 1 ohm is if either you had 2 speakers with 2 ohms a piece, or if you had 2 dual voice coil speakers with 4 ohms each coil.
    PROGRESS:
    Jul 2008
    London,Oh
    thanks hears the info that i know
    the subs are dual voice coil memphis 4 ohms a peice not sure the model they are older with the orange basket and a magnet that looks like it can come off the amp is a 1606d hifonics brutus the specs are
    4 ohm 550x1
    2ohm 1100x1 these don't say peek power or RMS
    1 ohm 1600x1
    dampening >250
    singal to noise>95db
    thd&noise<0.08
    variable input leavel (unbalanced)0.2-9v
    input leavel comtrol (balenced)0.04-18v
    input impedance(unbalanced)47k-ohm
    input impedance(balanced)20k-ohm
    hears the specs i thought you might have wanted but i have'nt done car audio in 6 years other then "hay you hook this up and tune it " but i guess thats what it is so info is grately apprisheated and thanks
    Jun 2005
    chicago, Illinois
    So with your current setup you cannot increase the performance or effiency without changing out the components, ie amp or subs.
    PROGRESS:
    Jul 2008
    London,Oh
    did a cuple tests
    I checked if un hooking one sub made a diffrence and it sounded the same as two so I then checked to make sure it was the same with the other and it was so i checked the volts at the amp and they are way low so i got a memphis lighting cap but still need to hook it in line and see what happens and by chance whould any body have a idea as to how many watts the subs I got might be theyare 07 model memphis
    they are 800 watts peek and dual 2 ohm voice coil that mean I should wire diffrently
  1. Micro Star Motherboard Problems with Power Switch/BIOS
    By Sidewalksalvage in forum General Hardware Discussion
    Last Post: 06-26-2006, 01:40 PM
  2. Replies: 5
    Last Post: 04-24-2006, 04:16 AM
  3. Replies: 0
    Last Post: 04-18-2006, 01:49 PM
  4. Vector Power invertor 400/800 watt power
    By Jir1984 in forum Classified Archive
    Last Post: 08-20-2005, 03:43 PM
  5. sproggy psu 2.8 max power
    By nicgalla in forum Power Supplies
    Last Post: 08-03-2003, 04:15 AM
