Results 1 to 2 of 2
Thread: Splitting Audio from 2 sources to different speakers?
    Jun 2003
    Memphis - TN
    Im wanting to setup my system to play different inputs to different speakers.
    Basically, heres my dillema. I am setting up a carPC in my wifes car with dual monitors. One touchscreen up front via VGA, and a second monitor on the back seat via composite. I would like to be able to have audio playing on the front two speakers, and a different audio source playing on the rear ones, such as audio from a movie.
    Is this possible?
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    FLAC WuNgUn's Avatar
    Sep 2007
    You could probably do this easily with AudioMulch or CONSOLE...
    Have 4 inputs (from two seperate devices) and "patch" them to the outputs you want to use...
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. OEM Navigation Connectors
    By Mr Castulucci in forum General Hardware Discussion
    Last Post: 07-20-2010, 06:25 PM
  3. SD crashes on startup
    By mangus580 in forum StreetDeck
    Last Post: 10-05-2007, 12:14 PM
  4. Whats the easiest way to get audio into speakers?
    By TimW in forum General Hardware Discussion
    Last Post: 03-14-2000, 08:36 PM
