Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Will this wiring work?
  1. #11
    Sep 2007
    Sunny Florida
    I have a 2007 ford mustang with a shaker 500 system. Okay so after some gathering of data here is what I think will happen.
    Stock amps will power the two subs like usual.
    I will convert my 3.5 jack to rca cables and run them into my 4 channel amp (200 watts)
    Run speaker wires from the amp to the stock radio harness.
    50w per speaker seems to be okay from what I've read just as long as you don't crank it to the max. I will be purchasing new speakers in the future though and running my own speaker wires to the.
    This should do the trick correct?
  2. #12
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    with the correct interface, it should work like you described
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  3. #13
    Sep 2007
    Sunny Florida
    Quote Originally Posted by scott_fx View Post
    Alright cool I will give it a shot. If anything goes wrong I guess I will just go back to step 1 and try it again.
  4. #14
    Sep 2007
    Sunny Florida
    One last thing. Say I get a 4 channel amp but it's over 200 watts. Is there a way to restrict the amount of watts going to each speaker? Is this something that would be on the amp or would I need some kind of resistor?
  5. #15
    Dec 2004
    Los Angeles Ca
    just set your gains correctly and you'll be fine. Actually more power is better as a general rule of thumb. it give you something called 'headroom'... AS LONG AS YOU SET YOUR GAINS CORRECTLY :-)
    i think there is a write up in the audio faq.
    M10k
    My Car Pc Install
    My Boat Pc worklog
  6. #16
    Sep 2007
    Sunny Florida
    Okay another thing
    Instead of running a new wire from the battery to the computer am I able to use the stock radio wire? I haven't looked at the gauge of the wire but the pc isn't using too much power. What is the main downside of doing this just maybe not having the power when needed?
  7. #17
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    The main downside would be fairly hypothetical, but could happen. here it is: CarPC pulls too much power causing wires to overheat, melt the covering, short out, blow up the battery, set the car on fire. Sure there are safeties in place, like fuses... but could happen. More than likely, you'll just pop a fuse.
    Just do it right and run a new wire for your CarPC, with it's own separate fuse, etc. It'll be better in the end.
    Tidder
    Try RevFE
  8. #18
    Sep 2007
    Sunny Florida
    Okay I already ran a new wire to the trunk for the amp I just didn't feel like getting dirty again if I didn't need to. I was going to run a new line anyways I don't like to half *** stuff really. Even when I do I just end up going back and redoing it the correct way.
    Another question
    I know I'm asking a lot of questions and I thank you guys for all the help.
    If I get a 2 channel amp 200w I could wire the left 2 speakers and the right two speakers and run them to the amp right? That would in theory push 50w per speaker if they all see equal amounts. Or will the amp just push 100 to the left and 100 to the right and who ever gets it gets it? What would be the best way of doing it? It's hard to find 200w 4 channel amps.
  1. AWG wiring issue on M2-ATX...???
    By Nazx in forum Newbie
    Last Post: 03-31-2008, 08:03 PM
  2. Replies: 5
    Last Post: 03-02-2008, 06:23 PM
  3. Replies: 14
    Last Post: 01-28-2008, 12:33 AM
  4. My setup and wiring.. does it work..
    By Ryann in forum General MP3Car Discussion
    Last Post: 08-22-2006, 09:57 AM
  5. sound system wiring advice and componant choices for a newbie
    By dbzeag in forum General Hardware Discussion
    Last Post: 08-27-2004, 07:44 AM
