Results 1 to 10 of 18
Thread: Will this wiring work?
    Sep 2007
    Sunny Florida
    Okay I'm not going to be running a headunit at all. With that being said here is what I have in mind will it work?
    I'm going to use a 3.5mm to rca cable which will be plugged into a 4 channel amp (or should I use a 2chanel amp?). I will then use a wireharness adapter and run speaker wires from the amp to the wireharness.
    Am I missing something or is it as easy as that?
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    are you using stock speakers? is there a stock external amp? how many speakers do you have? what is the power of the amp?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Sep 2007
    Sunny Florida
    Quote Originally Posted by scott_fx View Post
    Yes stock speakers
    Yes there is a stock external amp (I'm not sure what to do about that yet)
    4 speakers 2 tweeters (I don't really need the tweeters though)
    I don't have the amp yet I'm looking to get one. The amp that powers the stock speakers is 500 though so I would think somewhere around 500ish I would go with.
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    Quote Originally Posted by 04silvertib View Post
    yes
    you can use either a 2-channel or a 4-channel. either way it will be 2-channel (stereo) audio.
    if you use a 2-channel amp you will have to wire the front left and rear left speakers in parallel and the front right and rear right speakers in parallel. this will cut their impedance in half, make sure the amp can handle that impedance load.
    if you use a 4-channel amp then you will have to use a couple RCA-RCA Y-adapters to split each channel in two (unless your amp has a 2-channel input mode, my Pioneer amp has that feature).
    just remember that your amp will probably put out more power than your factory wiring was designed to handle. so if you're going to run an amp that is significantly more powerful than your car's factory HU, then you may want to bypass the wiring harness and run thicker speakers wires from the amp directly to the speakers.
    in it's most basic form, yes it is that easy. but you will have to control your volume and EQ settings through software/touchscreen interfaces. some people are ok with that, others are not.
    I personally hate touchscreen volume/EQ control. it forces you to look at the screen just to raise or lower volume. some people use USB volume knobs but that is still software controlled, so if the PC locks up then you have no volume control!
    I wanted a true hardware-based volume/EQ solution, so I bought a Clarion EQS746 1/2-DIN equalizer. it takes a single 2-ch RCA input and outputs 3 independent 7-volt RCA pre-amp outputs (front, rear, and subwoofer). you can control the volume of each output independently and from the master volume knob. as well as volume control you get 7-band EQ control and subwoofer volume/crossover control without having to look at the screen.
    good luck
    Dec 2004
    Los Angeles Ca
    Yes stock speakers
    if yo uhave an external amp, it's best to run new wires to the speakers
    this poses a problem. you would need to figure out either a passive x-over or go active... both would be too much of a hassle. your best bet may be to replace both of them with a coaxial speaker or component set if you have some extra cash
    the amp that power the stock is proably 15 watts per speaker (realistically)
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Sep 2007
    Sunny Florida
    After a little more research I found out the car has 4 speakers 2 subs and 2 tweeters. It also has 2 amps powering each sub. The car is rather new so I'm still learning the ins and outs. This makes things a little harder now.
    Dec 2004
    Los Angeles Ca
    check out the options for oem interfaces (i.e. pac-audio, peripheral, soundgate) and see what they have available to tie into the factory system. you may be able to get away with a small 4 chan
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Sep 2007
    Sunny Florida
    I found this
    http://www.logjamelectronics.com/piefrd04aux.html
    It plugs into the stock harness and allows you to plug in aux or rca cables and it will play it through the stock speakers without using the stock radio. I think it will work wont it? I can hook that up and then run an aux cable from my pc to that unit. My pc will power the speakers in the car and the stock amps will still power the 2 subs. Can someone take a look and correct me if I'm wrong?
    Dec 2004
    Los Angeles Ca
    you'll need to retain the stock stereo with that piece
    what kind of car do you have?
    M10k
    My Car Pc Install
    My Boat Pc worklog
    May 2007
    Boston
    you may be able to use the stock subwoofer amplifiers to power your subs but you will still have to use an outboard amplifier to power your regular speakers.
    your PC cannot directly power any car speakers. your PC's audio output is a low-level pre-amp output. the signal needs to be amplified by an outboard amplifier.
  1. AWG wiring issue on M2-ATX...???
    By Nazx in forum Newbie
    Last Post: 03-31-2008, 08:03 PM
  2. Replies: 5
    Last Post: 03-02-2008, 06:23 PM
  3. Replies: 14
    Last Post: 01-28-2008, 12:33 AM
  4. My setup and wiring.. does it work..
    By Ryann in forum General MP3Car Discussion
    Last Post: 08-22-2006, 09:57 AM
  5. sound system wiring advice and componant choices for a newbie
    By dbzeag in forum General Hardware Discussion
    Last Post: 08-27-2004, 07:44 AM
