Results 1 to 10 of 16
Thread: DAC, multiple outputs?
    Jun 2007
    Oxnard, CA
    Hello,
    I am using a VIA M10000 and looking at using a DAC to get sound to my two amps.
    One amp is controlling my front left and right comp set (passive x-overs), another amp is just for the subs.
    I would like to have a DAC go from the PC to each amp. Is this possible? Or do I need two DACs (One for each amp).
    Is it possible to get a Bloat DAC with multiple RCA outputs?
    (Trying to grasp my options).
    Thanks!
    Constant Bitrate b3tts32's Avatar
    May 2006
    Arlington, Tx
    Not sure if I'm completely getting your setup but I think I have something similar. I have a 5 channel amp that outputs to a crossover for my highs, mids, and sub. From the crossover goes to my dac which is then connected to the computer. I don't believe you would need more than one dac but that is just me..
    Jun 2007
    Oxnard, CA
    Sorry not a very good description of my setup (heres a quick MSpaint version of what I was hoping to be able to do)
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    there aren't any multi-chan dac's out there that i know of. well, they have multi chan ic's but not a dedicated dac. your best bet would be to go with a bloat or twisted pear dac into the stereo input of your amp, then use the amp's pre-outs to get the signal to the subs. the drawback is that you'll have to use the amp's x-overs but depending on your setup, it could be just fine
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Jun 2007
    Oxnard, CA
    Hi Scott_fx,
    Thank you for the suggestion. Unfortunately I'm having a hard time understanding. Are you saying, wire from the DAC to the 4ch amp then to the 2 channel amp?
    Thanks,
    Incudie
    Dec 2004
    Los Angeles Ca
    yup, what amp do you have? some amps will have a pre-out that will pass the original signal on to another amp. another option is just to get rca y-adapter that will give you two identical stereo ouputs as well.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Jun 2007
    Oxnard, CA
    sweet thanks. I have an
    Ipaul 4.300
    http://195.243.203.21/rainbow/techni...112112&lan=ENG
    Actually, I have not purchased the other amp for the sub yet
    Dec 2004
    Los Angeles Ca
    http://www.talkaudio.co.uk/index.php...d=212&Itemid=1
    -RCA inputs for four channels plus RCA throughput sockets
    looks like you're good to go. nice amps btw...
    hmm... if you're going the route of rainbow amps... what speakers are you going with?
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Jun 2007
    Oxnard, CA
    Thank,
    SLC 265 Kicks =)
    Dec 2004
    Los Angeles Ca
    you should just run active and screw the dac :-)
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. Carputer Help Multiple Video Outputs
    By SuperEco06 in forum General Hardware Discussion
    Last Post: 04-13-2008, 10:24 AM
  2. Triggering multiple outputs with 1 image
    By rgarjr in forum Fusion Brain
    Last Post: 04-05-2008, 04:55 AM
  3. usb non oversampling dac with us in mind
    By scott_fx in forum Car Audio
    Last Post: 09-18-2006, 11:46 PM
  4. Multiple audio outputs
    By schnaarf in forum MacCar
    Last Post: 08-04-2006, 08:25 AM
  5. Multiple Sound Outputs
    By djXternal in forum Car Audio
    Last Post: 10-04-2004, 03:58 PM
