sub out to your amp, then from your amp you power both subs. you have to pick your amp and subs before we can tell you how to wire them.
Well i know this question has been asked multiple times, but i still need some help on an issue. Now the headunit i have in my car has its front and rear outputs and also one subwoofer output. I want to hook up 2 subwoofers to that one subwoofer line and im not sure how to do it. Should i split before a 2 channel amp and run that single line through both channels, or should i split it after a mono amp and run it to the two subs. Also should i wire in series or parallel. I havnt purchased any subs or amps yet so i want to know whats the best way to go before i do
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
