Results 1 to 6 of 6
Thread: Getting Audio to stock speakers and sub.... thoughts?
    Low Bitrate Ricksastar's Avatar
    Dec 2007
    CT
    I will be using the stock speakers also I have a mono AMp for my subwoofer.. What does everyone recommend for a set up of this? Also where is a god place to get something that will convert my wire harness to what eve i need to get to the pc?
    Elsewhere
    If the stock headunit has AUX input or CD changer input, you can use that. You may need an adapter, depending on stereo system. They're all different.
    As far as "converting a wiring harness", I have no idea what you mean by that.
    Most of us run a power line straight to the battery for the PC. No wiring harness involved.
    Don't forget to fuse the power line at the battery!
    How about the Wiki?
    Dec 2007
    CT
    I apologize... I was not very clear.
    I am not using a Head unit (screen is there now). So as for the wire harness converter, i meant since i have to patch into the stock speakers some how, now that I do not have the head unit.
    Dec 2007
    CT
    bump
    May 2008
    Without a HU, you're going to need an amp to drive your stock speakers. Your sound card just doesn't have the power to do it on its own.
    Sep 2007
    West Springfield, MA
    I suppose that you could use a wiring harness that is intended for installing an aftermarket radio. The ones I've used in the past have labels on the wire telling you what exactly they're for. This would make it easy to wire into the speakers, but you would still need an amp taking the signal from your soundcard and making it strong enough for those speakers.
  1. Will stock alternator provide adequate ampage? (CPU + Sub)
    By Cadillac_LoungN in forum Power Supplies
    Last Post: 07-07-2003, 02:52 AM
