Results 1 to 4 of 4
Thread: help!!!car audio dies when i turn headlights on???
    Aug 2008
    i just hooked up my touchscreen and now i have a small problem the screen works wonderfully during the day but the minute i turn my headlights on the audio dies.please all advise will be helpful
    Feb 2008
    Perth, West Australia
    I'd say the problem is where you got the power, or more likely where you earthed it.
    Common mistake it to earth to the illumination sense wire from the dash, as it reads (on a multimeter) like an earth when lights are off.
    Rewire correctly and check appropriate fuses.
    Aug 2008
    grounding
    You are using your illumination wire as your ground wire...you are lucky, usually it blows your tail light fuse...
    you need to undo the wire that you think is your ground and just get a good chasis ground...
    good luck
    Allen Jenkins
    President
    702 Motoring
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    i third that... what they said
  1. SD crashes on startup
    By mangus580 in forum StreetDeck
    Last Post: 10-05-2007, 12:14 PM
  2. Replies: 19
    Last Post: 12-04-2004, 06:37 PM
  3. Seperate VGA and S-Video with Audio
    By Fox_Mulder in forum General Hardware Discussion
    Last Post: 07-01-2004, 02:44 AM
  4. Replies: 4
    Last Post: 03-25-2004, 06:53 AM
  5. Need some help with sending audio to stock amp
    By orangewhip in forum General Hardware Discussion
    Last Post: 09-04-2003, 02:21 PM
