Results 1 to 2 of 2
Thread: Power Supply to Car amp
    Aug 2008
    I recently got a power supply out of a Dell Optiplex Desktop. I hooked the PSU up to my car amp so I could play my games through the subwoofer. Ok there is a green wire and a black wire I spliced and twirled together. This lets the PSU turn on without having to be plugged into the motherboard. After this you connect one of the yellow wires from the PSU to the 12volt on the amp. Then you connect a black wire to the ground on the amp. Well the problem I'm having is when I turn the power supply on the fan starts going and then I see the light on the amp come on a good sign. Then the amp and power supply just turn off. But the wierd thing is that I can hold the green and black wires together until the amp start to come on. Then I just tap the two wires together and the PSU and amp run without stopping. It's like I have to get the PSU started up before it can get enough power to start everything. Also when I turn the amp up to loud it shuts off and I don't turn it up that loud. I'm thinking the power supply might just not be powerful enough. If anyone know please comment. Thanks
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    not sure about the turning on and off but as far as shutting off when you turn it up, it's because you blowing way past the specs on that 12v line. that thing is probably rated at 10 amps on the 12v line, the amp could be pulling anywhere from 40-100 amps
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  1. Replies: 115
    Last Post: 03-05-2011, 04:54 AM
  2. Review: M4-ATX 250 Watt Intelligent Power Supply
    By Bugbyte in forum The Review Palace
    Last Post: 12-21-2009, 09:52 AM
  3. Car Battery Charger / PC power supply
    By stpenn123 in forum Power Supplies
    Last Post: 01-28-2008, 12:33 AM
  4. FAQ: Will <insert PSU model> Power Supply work with my system?
    By DarquePervert in forum The FAQ Emporium
    Last Post: 10-10-2006, 01:38 PM
  5. Replies: 9
    Last Post: 06-08-2006, 06:15 PM
